Relay control problem
SimonM
I am working on a projet that uses latching relays. They latch when you put a polarity or the oposite (set = +/- reset = -/+). The problem I have is that I cannot find a way to control the relay I.E control the ground and +5v of the relay.
Is there a way to assign a I.O to ground and switch it back to +5v or something similar?
Simon
I'm not sure what you are asking exactly.
One of the most basic things a microcontroller can do is set an I/O pin to Vdd or ground.
This is exactly what I need to do actualy. I am confident that you can swap it at any time when you want? I must say that I am new to the uc design and principles. Do you have a quick example of how it works?
For the H Bridge, it is a good idea and I was thinking about it, however it introduce more hardware and it is something that I want to reduce.
Thank you both for the quick response. I truly appreciate it.
Simon
What current does the relay require to latch the relay? If it is low enough you should be able to drive it directly from a PIC.
Use an NPN transistor with a back emf diode.
Put a 1k or 2k / 2.2k resistor in series with the base of the transistor and the PIC IO pin.
Thanks for all the answers and discussion about this.
THe current I draw is about 0.020 a per Relay when I toggle them. I use single coil latching device and they are not ''pulse toogle''. I must invert the polarity.
I know that dual coil are easier to drive, but I need to keep the number of input low to reduce the number of hardware on the board.
For now, I think that the only possible solution is to use a H-Bridge. I have depleted other type of solution since I got 16 relays to activate. Using a H-bridge will allow me to drive them all (actualy I divide them in two packs of 8).
Thanks for the help :)
Simon
