Hello, I have a circuit that consists of three op-amps (TLC2272CN) and one instrumentation amplifier (INA116). For my purposes, I need to use +/- 6 Volt dual supplies to power these devices.
I was considering using two of these batteries, http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P143-ND, back-to-back to give me my supply range, but it occurred to me that I need to regulate these batteries.
I am now not sure what to do. I like the fact that these coin cells are small, but they only have a 165 mAh capacity and I need a regulated +/- 6 V.
I heard about boost converters, but I think they will take up too much room on my board.
I posed the idea of getting two 9 V batteries and two 6 V regulators, but I am not sure if that will be sufficient.
It says that the both amplifiers require 1.5 mA per channel (max) so I figure that gives 165/6 = 27.5 hours of lifetime for the 6 V coin cell batteries. My device will not be on for longer than a couple minutes at a time, so I don't think power consumption is an issue.
So to sum up, should I just go with the 9 V batteries and regulate down to 6 V, or should I go for the coin cells and somehow regulate them?
Thanks again!
Thanks again!
