Receiver Circuit HT12D needs help
Its OK you don't need any output resisters.Don't forget not to exceed more than 5V supply.
To make sure your HT12D is working you can remove 74HC154 & put 4 LED's to output of the HT12D chip via 330R resisters.When a valid signal receives you will light the corresponding data bit.
that what i did, everything is working fine on the breadboarding. but when i change to pcb its not working..
heres the brd for my pcb
forgot to explain how my whole circuit works. so i have a limit switch which have (COM and NC) the COM would go to the output PIN 2 & 3.
and the NC would go to the INPUT of a LS7404 hex inverter as the output of my 4 to 16 74LS154 is output low. then finally the outputs come from the inverter to my L293D to drive my motor.
View attachment 65595View attachment 65596
i tried connecting my PCB of motor to my Bread boarding of receiver and it works.. but when i tried the PCB of my receiver to my motor PCB and breadboarding it doesnt work.. need advise on these..
