reading writing to eeprom
I did the suggestions in post 46 and 50
I did gain an understanding of what is happening.
now I am attempting to use the examples and get my project to maybe advance further..
trying to abide by the suggestions Tumbleweed made in post 58
after I finish writing a short code snippet similar to the two sub routes in my project where the code writes and reads the scores I will post it.
well something must be working but? the LCD shows 123, 0, 48, 14388
I shut off power and ture it on and the lcd displays 14388. BUT ms is 45 not 48. Going to run with the
If prev_score < LastHighScore instead of If prev_score > LastHighScore
// working variables...
Dim Value As Byte
Dim Str As String
Dim x As Byte
Dim sw As PORTA.0
Dim ms As Word
Dim s As String
Dim time As Word
 Dim LastLOWScore As Word
 Dim Prev_score As Word
 Dim score As String
Dim tmpByte As Byte
    Dim LastHighScore As Word
ms=45
Prev_score=123
LasthighScore=256
's=DecToStr(ms/1000)+"."+DecToStr((ms Mod 1000)) //players current score
while true
    EE.Read(0,tmpByte)
    If tmpByte = $77 Then
        EE.Read(1,LastHighScore)
        writeat(1,1,dectostr(LastHighScore)) //
    Else
        LastHighScore = 0
        EE.Write(0,$77,LastHighScore)
        writeat(2,1,dectostr(prev_score))   //
    EndIf
    delayms(4000)
     cls
    'Dim LastHighScore As Word
    If prev_score > LastHighScore Then
        EE.Write(1,dectostr(lasthighscore))
        writeat(1,1,dectostr(lasthighscore))  //
    EndIf
    delayms(4000)
     cls
 wend
You have too much gunk going on there
You write like this
EE.Write(0, 1223)
You read like this
dim Value as word
EE.Read(0,Value)
You print it out to LCD
LCD.WriteAt (1, 1, DecToStr(Value))
You don't need nothing else you only want save the game value.
Post removed pending investigation of some screwy results.
Disregard the image for the time being.
I assume that SFB reads/writes words as you would expect (little endien) and the reading is confirmed by your code. Can you confirm that it writes words as expected?
I'm getting some screwy results that I can't explain as I go a little farther into this. I'm going to remove the post for now until I can verify my results.
It's not helping that my PC is being a pain in the butt right now too.
(Poking nose in ) I have a few months spare time to fill, so had a look at SF and saw this on the forum....
I use EE.Write as it seemed meant to be the 'generic' way to do things and it would automatically choose to write it as a longword. You are correct though that if I specified the data size to write it would work OK. I usually avoid this if I can as it makes changing the type prone to error.
I might even install SwordFish myself.
As a total linux.mint fan boy I will give it a go nested in ' wine '
Edit {done=30min} My first open of SF looks a steep learning curve for me , my basic days were with Qbasic and turbo Basic ( dos ) there seems to be a trap for ' old young players ' using all the include modules, insomuch as being able to micro control the data perhaps i am being fussy. coming from assembler ( and then C, ) my asm 'eeprom (PIC device ) write' was about 18 lines or so , EEPROM.bas has about the same subs and functions .. however i was dealing with one pic device so no #if #ifelse etc were required .. I can visualize how this would fill memory with un-used code ?
Not at all, the #if etc. are assembler directives, not part of the code so don't make the code any larger - it's simply a matter of selecting which parts of code are included, those not required aren't added.
Nigel thank you , is there a way to change the SF editor font size plz ?
Forget what i said its under Options Highlighter !
another 2 cents worth SF EEPROM Library Note
Quote " Important - you should disable the global interrupt flag (GIE) before making calls to an EEPROM write routine that modifies more than a single byte .."
The code mrdeb posted is writing a lot
All he needs to do is write his game value pull it out and compare it raw
If he wants to print format it from the raw value
SF is pretty good and I would expect that interrupts are disabled during the required write sequence. And, why is a single byte ok?
Sorry, just reread your post, that's in the library module?
You found it. You can select any font you like, the size, font colors for different features, etc.
I recommend a mono-space font that has good differentiation zero and "oh", one and "ell", etc.
I think I got it figured out and ran it several times. It is not perfect but very close to desired where the Best_score is what I am after. even if current score is lower then current score becomes best score. I inserted arrays for current score and best score to avoid having to press buttons all morning.
Device = 18F43K22
Clock = 8
#option LCD_DATA = PORTD.4
#option LCD_RS = PORTD.2
#option LCD_EN = PORTD.3
'#option KEYPAD_PORT = PORTC
Include "intosc.bas"
Include "setdigitalio.bas"
Include "keypad12mrd.bas"
Include "ledmatrixREV.bas"
Include "lcd.bas"
Include "utils.bas"
Include "convert.bas"
Include "isrtimer.bas"
Include "EEPROM.bas"
Include "Convert.bas"
Dim Value As Byte
Dim Str As String
Dim x As Byte
Dim sw As PORTA.0
Dim ms As Word
Dim s As String
Dim time As Word
dim z as byte
 Dim score As String
Dim tmpByte As Byte
dim current_score as word
dim Best_score as word
dim et(5)as word
dim A(5) as byte
//current scores
a(0)=125
a(1)=135
a(2)=45
a(3)=55
a(4)=75
//best scores
et(0)=50
et(1)=75
et(2)=35
et(3)=20
et(4)=300
'current_score=100
ms=45
'Prev_score=123
'Best_Score=282
while true
    for z = 0 to 4
    current_score=A(z)
    best_score=et(z)
    ee.write(1,best_score)
    EE.Read(0,tmpByte)
        EE.Read(1,best_score)
        end if
        if current_score < best_score then
          best_score = current_score  //reset BEST_SCORE if CURRENT_SCORE is lower
          EE.Write(1,best_Score)  //present beast score
          current_score=0
        endif
        cls
      EE.Read(1,Best_Score)
        writeat(2,1,dectostr(current_score))      //14388
        writeat(1,1,dectostr(best_score))   // 123
    delayms(4000)
     cls
    next
 wend
It automatically disables/enables interrupts around the low level single WriteByte() routine, but larger data types make multiple calls to WriteByte() so it could always be interrupted between bytes (ie longword=4 bytes).
It's up to you to decide if that's important or not.
As Nigel pointed out, SF will automatically remove all of the unreferenced code for you, so even of the module is 32K you only get what you need.
