Hi !
Is there any way to copy the contents of this microcontroller?
Thanks in advance
Part Number: DS5000T–32–16+
RAM size: 32K bytes
MAx Crystal Speed: 16 MHz
TimeKeeping: Yes
8-Bit 8051-Compatible Microcontroller
Adapts to Task at Hand
8 or 32 kbytes of Nonvolatile RAM for
Program and/or Data Memory Storage
Initial Downloading of Software in End
System via On-Chip Serial Port
Capable of Modifying Its Own Program
and/or Data Memory in End Use
Crashproof Operation
Maintains All Nonvolatile Resources for 10
Years in the Absence of VCC at Room
Temperature
Power-Fail Reset
Early Warning Power-Fail Interrupt
Watchdog Timer
Software Security Feature
Executes Encrypted Software to Prevent
Unauthorized Disclosure
On-Chip, Full-Duplex Serial I/O Ports
Two On-Chip Timer/Event Counters
32 Parallel I/O Lines
Compatible with Industry Standard 8051
Instruction Set and Pinout
Optional Permanently Powered Real-Time
Clock (DS5000T)
Thanks in advance
RAM size: 32K bytes
TimeKeeping: Yes
Temperature
Power-Fail Reset
Watchdog Timer
Clock (DS5000T)
