The output of U11 is centered about GND, but the output of U13 is just DC at the opamp's maximum positive saturated output value. Are you asking about adding a DC component to the output of U11 before it goes to U13? This can be done with a coupling capacitor and some bias resistors.
ak
If you made the (+) supply +10V, the negative supply = 0V, and what was gnd now is +5V.
Now your output will be from +1V to +9V.
This is close to what you want.
Where?HAs you can see, i added capacitor,
Where?
The voltage circled in red sets the center of the wave form. Try setting this to 5.5V or 6V and watch.It's perfect. How you calculated that it should be from +1 to +9 V. What is equation can i use if i need from 0 to +5 V?
What is the purpose of U13? What signal do you want at its output?
ak
The capacitor you added prevented a reference voltage on the (+) input of the 3rd opamp.
Your SIM program did not read the datasheet for the TL031 opamp:
1) The TLo31 opamp inputs do not work if they are within 1.5V from the -5V supply but your 3rd opamp has its (- ) input directly at -5V so it will not work.
2) The output of a TL031 opamp cannot go anywhere near the +5V power supply voltage, some will go only as high as +3V.
The stupid SIM might work but the real circuit will not work.It works perfect if i have power supply -5 - +5 V
1) An opamp cannot work without a DC reference voltage on its (+) input within its common mode input voltage range.
2) The output of a TL031 and most other opamps cannot go anywhere near its +5V supply voltage.
Maybe the huge value of your capacitor C4 takes a few days to charge with the very low leakage current of the Fet-input opamp.
Here are the other problems with the opamp U13:
