Hi VNE,
No problem about explanation- I learn a lot from these threads.
Rather than explain all the connections, if you would like to see circuits for any of the options I can probably post an outline schematic.
At this stage, if you could point at an approach that you would be interested in from a user/builder point of view, that would be the best way forward. Once that is decided we can thrash out all the technical aspects. And often you find that when a trial circuit is done problems are revealed and you may go for another design approach as a result.
Yes, you are switching infrequently, but it is is still important that the MOSFETs turn on and off smartly or they may exceed their safe operating area while they are turning on and off. There could be other problems too, with the massive gate charge and possibly leakage currents.
Sorry.
spec
Spec,
Thanks for your explanation in post #17. I think I now understand why the 7912 would be necessary, but I'm still a little fuzzy on specifically how I would use it. The data sheet for the UCC21520 only has an example schematic using NMOSFETs which I believe is what your option 3 from post #13 describes. If I swapped out the top side NMOSFET for a PMOSFET, as in option 2, I'd have to do a little thinking about what else I'd need to change, but specifically with respect to the 7912 you said:
But the 48V connected to the top side drain will be variable. I'll call it VTD. In reality, I'd want the output of the 7912 to always be 12V less than VTD, correct? If that is indeed the case, would I hook up the 7912 as follows?
input = VSSA, ground = VTD, output = VTD -12V
Similarly, if I went with option 3 from post #13, would I hook up the V- output of the wall wart to VSSA?
Tomizett's suggestion is quite innovative and the VOM1271 is certainly a useful chip, but I am afraid that the VOM1271 just does not have enough gate drive ability, at only a few micro amps, for the size of MOSFET that will be required for your application.Does anyone have any thoughts on changing direction to use the VOM1271 in lieu of the other driver ICs previously discussed?
Sorry.
spec
