PWM circuit to drive ignition coil
TACAMO
Hey Electro Tech, I want to build a High Voltage spark generator using an ignition coil. Ive read that using PWM circuit work great for this. So I was looking at this kit,
Its a motor speed controller, but could I use this to drive an ignition coil.
It would be easier and much cheaper to just build one yourself. All you need is a basic Timer IC like a 555 or something similar to drive a high voltage Mosfet or IGBT switching device.
This has been done on this forum before.
Feed the ignition coil from a lamp dimmer, set to half brightness, via a motor start capacitor.
Generally a PWM motor controller should work.
Consider the high clock frequency when pulsing an ignition coil, which might overheat.
Here is a cheap circuit using the CMOS-version (TLC555) of the NE555.
The PRF (pulse repetition frequency) is fixed at 1 to 1.5 cycles/min with selectable pulse widths of 16.5, 24 and 31ms.
Boncuk
Note: S1 is a double pole three position slide switch for circuit safety reasons. If a single pole switch is used and fails the timer output might constantly go high causing the ignition coil to overheat and "kaputt". Don't omit the fuse for that reason.
Check Out My Circuits.
Take care.....Gary
