Now i'm trying to do a dual opamp, MCP6002, one symbol including the power pins. Do you know how to do this?
I can do this easily in Eagle Pro. You just make two symbols separately in the lib...then shovel them both in when you make the "part".
...So now i have got the Part A and Part B in the lib...but it only places one of the parts on the schem sheet.
In the components window, it doesnt show the dual opamp as a 2 part device...but in the schem library, it shows as a 2 part device.
Ive just watched 2 altium videos on how to do this, and none showed how you get the components lib to show the 2 part device.
Even the Altium documentation doesnt show you how to do this....
resources.altium.com
electronics.stackexchange.com
Creating PCB Multiple Parts Components and Symbols in Altium Designer
How to create multi-part components and symbols in Altium Designer®. Build a symbol manually or use an advanced symbol generator to do the heavy lifting of symbol creation for you.
How do I create a split component with shared pins between symbol parts on altium?
I'm trying to create a symbol for a dual op-amp on Altium designer, I want to have the symbols be the classic 5 pin representation of an op amp with both inputs, an output and the power pins. But w...
