purpos of branch with a capacitor leading to ground?
Triode
I'm wondering why on so many circuit designs, particularly ones involving ICs, there is a point, often right before the connection to the supply or drain where it branches to a capacitor, often 100nF or so, which connects to ground. Is this like a cushion for changes in current?
here is an example:
The odd thing is that looking at motor control designs, I have seen many that are almost identicle except for including or excluding these capacitors. And many chips have a similar branch to ground on their connection diagrams. So what does it do?
.1mf does not act like you describe. It's sole purpose in this application is to squelch frequency noise.
What kind of IC's are you using that use a lot of current when the logic state changes?
Note the 100u one mike, that's definitely a power supply buffer.
Yes, but that is on the other side of the voltage regulator and the original question is about the .1 next to the IC.
The 100uf is resisting changes in the current, kind of smoothing out any ripples in the DC.
But .1, no.
sometimes more than 100nF are required, for instance if you drive LED displays.
1uF, 47uF or even 220uF, if problems persist, add capacitors at multiple places until they disappear.
fast computer circuits (let say, 10MHz), which have RAMs, GALs, etc.,
need 100nF, 220nF or 330nF everywhere, not just one or two.
a CPU will introduce current surges in the 10s and 100s of mA, and if there are no capacitors, it can and will introduce logic glitches, means, the design can not work correctly.
for low-power PICs including some LEDs, i often just use 1 uF (note i supply via USB or battery, if you have 7805 etc., situation is completely different).
What C4 does depends on where it is located. If it is right at the regulator, then it is there to ensure regulator stability. If it is right next to the chip, it is a simple bypass cap for the logic IC to keep noise off the lines/provide low impedance to ground for AC noise. If it is close enough to both, it will act as both.
Doesn't C4 also help in keeping the regulator from oscillating?
an oscillating regulator is an unstable regulator. If a capacitor is being used to help maintain stability then it is preventing oscillatory behavior.
He's explaining in response to Krumlink that what he said as an alternative explaination is really the same thing.
