Ok, thank you for your help.Just normal little silicon diodes, the 'standard' one is IN4148
So this would be it:
Switch mode is best but its frequency sometimes disturbs and ripple comes in your way. So you need to be sure of its design and filter its output.y eah thats a simple solution as one of my regulators went bad and the led died by getting overvoltage. And another thing .... instead of messing with transformers why dont you use a voltage protector switch. It will allow voltages between 170-260approx. So when a surge is there it will help you.I think I will use switch-mode regulator...
Precise zeners 5.1-5.3 volts of high wattage accompanied by a 1 amp fuse
Is this ment for overvoltage protection for analog input? thanks
