Program compiled in Hi-Tech C for PIC16F877A, no result obtained
archanak2511
I've tried this simple embedded C Program using Hi-Tech C for PIC16F877A.
The aim was to obtain a logic high as output on 3 pins (pins D7, D2, D3 of port D), if one input pin (pin B6, of Port B) is driven to logic 1. The program was built successfully but after burning it to the microcontroller I got no result.
Program
#include<htc.h>
#define _XTAL_FREQ 20000000      //Clock frequecy=20Mhz
main()
 TRISB=0b11111111;                     //Set Port B as input port
 TRISD=0b00000000;                     //Set Port D as output port
 while(1)                                          //forever loop
 	{if(RB6==1)                             //if pin B6 is high
  		{RD7=1;                          //set pin D7 as high
	 	 RD3=1;                          //set pin D3 as high
	 	 RD2=1;                         //set pin D2 as high
 	 else                                     //  if pin B6 is low
   		{RD7=0;                       // set pin D7 as low
		 RD3=0;                        // set pin D3 as low
		 RD2=0;                      //set pin D2 as low
Please tell me if there is any mistake in the code or the logic.
did you set the fuses right? you have to set the fuse bits for the best working of the thing.
Ok, I had not read about such fuse bits. Will try to find out more about what these are how to set these bits. Thank you for the information :)
Just stick the following line at the top of the code.
__CONFIG(0x37F2);
The thing will be set for XT crystal and won't start...
I'll copied that and pasted it at the top of the code. But now when I compile it, its showing an error.
Error [194] C:\Users\TOSHIBA\Documents\project\test.c; 1.10 ")" expected
So I tried typing it with an extra bracket ")"
__CONFIG(0x37F2));
Now it was compiled successfully. I can't test if it works right now because I don't have the hardware or software required for burning the program into the microcontroller. But anyhow, isn't that a bit weird, one open bracket and 2 close brackets? :/
archana, its the same, the config bit of pic ( i'm more of an avr guy.. in avr config bits are called as fuse bits. ) refer page 146 of the PIC 16f877a datasheet for more info.
yeah both are the same but in pic datasheet there is no such thing as a fuse word. so to avoid confusion, I said so.. thanks Ian for the new info about fuse bits.
The config bits ARE the fuses... (Named a long while ago when they were fuses)
The code I pasted was ok... Show me where you put it!! It has to be at the top BELOW #include<htc.h>...
I was silly enough to paste it at the very top. Now that I've pasted it below the include statement it works fine. :) Thank you. :)
Could you repost the code with the correction. I'm a noob trying to learn the flow. It would really help me.
Regards,
kv
Hi KV
#include<htc.h>
__CONFIG(0x37F2);                 // Goes here...ish
main()
The _CONFIG(); is in the headers... Once you use <htc.h> it is automatically defined so you can use it..
