Carl Kremer
Hello.
First I am a noob to electronics but can solder and short a circuit.
Outline of problem.
I work for a company that makes plastic drainage membranes. These have to be guaranteed watertight.
Our production machine is 2.20 meters wide. Producing 2 meter wide rolls of membrane.
These membranes are either flat or studded with a thickness of .6 to 1.5 mm depending on product.
Due to impurities in some plastics, contamination etc there can suddenly appear small holes. 2mm to 1cm are common.
Current solution to problem (Which are terrible)
The membrane is extruded and shaped around rolls. It moves across a table which has a light tight box with webcams looking up at
the membrane. These are connected to a motion detection software which sounds an alarm when 1 or more cameras detect light/motion.
There are numerous problems with this setup:
1. Light leaks. (False alarm)
2. Some membranes are thin and light shines through. (False alarm)
3. Low frame rate and quality of image. (No alarm)
4, Dirt can cover lenses
5. Sometimes the computer doesn't communicate with the alarm controller. (Which is an adam thing)
6. Takes a lot of space.
7. The thing cries wolf and is not taken seriously.
8. Sometimes we run clear membrane. (Can't be used at all)
My idea for a solution:
I want to run 2 long strips of conductive brushes across the width of the membrane. (Anti static / conductive filament)
One mounted on top of the membrane and one on the bottom. The membrane keeping them apart.
These brushes would be charged somehow and if there is a hole the bristles touch giving a arch/short and sound an alarm.
Please see my totally awesome schematic (Done completely in MS Paint) at the bottom
Some requirements:
This needs to be somewhat safe. I can enclose somewhat so no hands go between but I don't want to kill anyone. A little shock is ok.
When a hole is detected the alarm will sound and the detector/power will be turned off (So it doesn't burn up I guess)
It will need a button to turn off the alarm and on the detector to detect eventual next hole (Reset button?)
Maybe a variable control to tune the power so that it will arch even if the bristles don't completely touch (So it can be tuned to thicker materials)
Possible problems that I can see.
Sometimes the hole is not complete. (The membrane might just be very thin)
Make it safe from people hurting themselves and fire.
Looking for some creative ideas for a setup like this. Wan't to make a prototype from off the shelf/cheap parts. I got faith this thing could work and be in one word "AWESOME" Please help me realize it. I will keep everyone posted of the eventual build.
Here are some parts I'm looking at (Don't know if they work or how to implement them)
Brush for prototype. (**broken link removed**)
How to power it? ( **broken link removed**) maybe this
My schematic :
Outline of problem.
Some requirements:
My schematic :
