Problems with programing a PIC12F675
delha87
We are trying to program a PIC12F675. Our project the control of the comfort of a greenhouse.
Inputs: - temperature sensor (voltage proportional to temperature, analog input)
- humidity sensor (two states 1 or 0)
Outputs: opening windows, irrigation, resistance, ventilator
If someone could give it a look and tell us what's wrong we'll be really pleased! We think the error could be that there is some missing register or something like that. Thanks!
Source code:
#include "DEFINITIU.h"
//Main() - Rutina principal
int c;
int TEMPERATURA;
void main(void)
Init();
while(1)
c=0;
sensor_T();
if ( TEMPERATURA < 128 )
encendre_resistencia; //swich on resistance
apagar_resistencia;
if ( TEMPERATURA > 128 )
while (c < 3)
obrir_ventilador; //swich on ventilator
c=c+1;
obrir_finestres; //open windows
apagar_ventilador; // swich off ventilator
tancar_finestres; //close windows
if (SHUM==FALSE) // there's no humidity
REG==ON; //swich on irrigation
else
GPIO2==OFF; //swich off irrigation
// Initialization Routine //
void Init()
TRISIO = 0b11000010;
GPIO = 0b00000101;
ANSEL = 0b00010001;
ADCON0 = 0b00000001;
return;
// Temperature sensor function //
void sensor_T(void)
GODONE = 1; // Swich on A/D converter
while(GODONE==1) // waits until A/D coneverter is done (GODONE=0)
//It does nothing
TEMPERATURA = ADRESH;
// OUTPUTS FUNCTIONS //
// Obrir el ventilador //
void obrir_ventilador(void)
GPIO4==1;
// Tancar el ventilador //
void apagar_ventilador (void)
GPIO4==0;
// Encendre la resistència //
void encendre_resistencia(void)
GPIO5==1;
// Apagar la resistència //
void apagar_resistencia(void)
GPIO5==0;
// Obrir les finestres //
void obrir_finestres(void)
GPIO3==1;
// Tancar les finestres //
void tancar_finestres (void)
GPIO3==0;
Header code:
#include <pic.h>
__CONFIG(UNPROTECT & BOREN & MCLRDIS & PWRTEN & WDTDIS & INTIO);
//Defines
#define ON 1
#define OFF 0
#define TRUE 1
#define FALSE 0
#define SHUM GPIO0
#define REG GPIO2
//Function Prototypes
void Init(void);
void encendre_resistencia(void);
void obrir_ventilador(void);
void obrir_finestres(void);
void apagar_resistencia(void);
void apagar_ventilador (void);
void tancar_finestres (void);
void sensor_T(void);
tresca
What is the error ? Compiler error ? Execution ?
If execution error, what should it return, and what is it that you are getting ?
delha87
the error is that when we put the microchip in his circuit it doesn't do what he is mean to. It only does the "Init()" function but it doesn't do the functions that link the inputs with the outputs.
Thanks!
Pommie
Most Helpful Member
When you post code if you type [code] before it and [/code] after it then it will keep it's formating and be much easier to read.
Anyway, should the following,
    apagar_resistencia;
be,
}else{
    apagar_resistencia;
I think the way the code is currently, it is always turning the resistance off.
EE World Online Articles
Loading
