Problem with turning PWM on and off
raitl
This is the part of my code that deals with the IR obstacle detection:
loop:
 call  IR_test
 call  go_forward
 goto  loop
;*******My subroutines*******
PWM_Enable:
 bsf  CCP1CON, 3
 bsf  CCP1CON, 2
return
PWM_Disable:
 bcf  CCP1CON, 3
 bcf  CCP1CON, 2
return
IR_test:
 call  PWM_Enable
 btfss  PORTA,0
 goto  IR_obstacle
 call  PWM_Disable
return
IR_obstacle:
 call PWM_Disable
 STEPS .10
 goto  Turn_right
return
And the problem is, that it won't toggle PWM. If I add call PWM_Enable before the loop: section, then it works but in that case PWM is always enabled which I do not want... I'd appreciate it if you could point me where the problem might be.
loop:
 call  IR_test
 call  go_forward
 goto  loop
PWM_Enable:
 bsf  CCP1CON, 3
 bsf  CCP1CON, 2
return
PWM_Disable:
 bcf  CCP1CON, 3
 bcf  CCP1CON, 2
return
IR_test:
 call  PWM_Enable
 btfss  PORTA,0
 goto  IR_obstacle
 call  PWM_Disable
return
IR_obstacle:
 call PWM_Disable
 STEPS .10
 goto  Turn_right
return
I don't really see what you are trying to do, but from the small section of code you posted it looks like PWM is turned OFF almost all the time, and only ever turned ON for a few microseconds.
that's correct. It's supposed to turn on PWM, then check if there is an obstacle in front of the IR transmitter and then act accordingly. But now that I think of it... the IR light "wave" might be too short to be successfully detected... I'll throw a delay in there and see what happens.
Yup! That's where the problem was :) Thanks
