Hi, I've a problem with a Microchip PIC16F876.
I'm trying to write to an external eeprom (24LC32A) with the following circuit:
https://digilander.libero.it/dibe84/cirORb.JPG
and the following source code (written in C18 and compliled with PICCLITE):
here, you can find the inclued files
https://digilander.libero.it/dibe84/include.rar
(I think they works, I find them here: www.jofi.it/fiser)
The program write only few values on the external eeprom (for example:
ExtEpromWrite(idDevice1, 0x0001, 0x11); // Scrive dato
ExtEpromWrite(idDevice1, 0x0002, 0x12); // Scrive dato
ExtEpromWrite(idDevice1, 0x0003, 0x13); // Scrive dato
it writes on the last value (0x13)....
But it isn't the only problem because the program not always ends: usually restarts before the end of the it (I understand it can't see the sequence of lamping leds by the end of program). In the other hand if I disconnect the SDA or SCL pin the program always ends.
You can help me?!?!?
(sorry for my bad english, but I'm italian)
bye!!
#include "pic1687x.h"
#include "macro.h"
#include "delay.c"
#include "exteprom.c"
#include "i2c.c"
void main() {
BYTE idDevice1;
BYTE data1;
WORD address1;
ADCON0 = 0x00; // Disabilita A/D convertitore
ADCON1 = 0x07; // Configura PortA come digitale
PORTA = 0x00; // Reset ogni linea
PORTB = 0x00; // Reset ogni linea
PORTC = 0x00; // Reset ogni linea
TRISA = 0x00; // Tutte le porte definite come output
TRISB = 0x00; // Tutte le porte definite come output
TRISC = 0x00; // Tutte le porte definite come output
PORTB = 0b00000001; //lampeggio i led per prova
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b00000001;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
DelayMs(250);
I2cInitMaster(); // Init I2c in modalità master
idDevice1 = 0x00; // Identificativo del device1
address1 = 0x00AA; // Indirizzo della cella eeprom utilizzato
data1 = 0x60; // Valore da scrivere nella eeprom
PORTB = 0x00; // Reset led
DelaySec(1);
ExtEpromWrite(idDevice1, address1, data1); // Scrive dato
ExtEpromWrite(idDevice1, 0x00B2, 0x22); // Scrive dato
ExtEpromWrite(idDevice1, 0x00A0, 0x64); // Scrive dato
ExtEpromWrite(idDevice1, 0x00A1, 0x65); // Scrive dato
ExtEpromWrite(idDevice1, 0x00A2, 0x66); // Scrive dato
//lampeggio il led alla RB0, fine programma END
TRISB = 0;
DelayMs(250);
PORTB = 0b11111111;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b11111111;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b11111111;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b11111111;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b11111111;
DelayMs(250);
PORTB = 0b00000000;
DelayMs(250);
PORTB = 0b00000001;
DelayMs(250);
PORTB = 0b00000000;
bye!!
