Hi, everyone
I'm having a little bit of a problem with my set-up (in the image below), and I could really use some of your help!
I designed a wheatstone bridge for a NTC (R(@25ºC)=470k) using 3x 505k resistors, and then created an intrumentation amplifier using the OpAmp TL082-n for the gain part plus the OpAmp in the PIC24 for the differential part. The problem is that, while the bridge is unbalanced at a voltage value less than 0.65V it works fine, but above that, the value at the output of the InAmp stays fixed at 1.30V.
I tried to find where the problem arises and it seems to be in the TL082-n, which doesn't vary its output values after the stated 0.65V - the outputs of both OpAmps of the TL082-n are: 2.70V (for the resistor-only bridge part) and 1.40V (for the NTC bridge part).
Do you know where I got it wrong?
Thank you very much!
Best regards,
José
Best regards,
José
