Problem using LCD on PortA and PortE with MiKroC
Nizar
Every thing works OK when I'm using Proteus with but in the reality when I make my circuit nothing appears on the LCD I'm using PIC18F4550 und LMB162A LCD my Cristal is 8MHZ
I think the problem is by using PortA or PortE when I use PortB or PortD every thing is OK.
Thank You all
This is my Code:
char *text = "Hello World";
void main()
  CMCON |= 0x07;             // turn off comparators
  ADCON1 |= 0x0F;           // turn off analog inputs
  TRISA = 0x00;
  TRISE = 0x00;                        // PORTB is output
  TRISB = 0x00;
  Lcd_Custom_Config(&PORTA,3,2,1,0,&PORTE,2,1,0);  // Initialize LCD on PORTB
  Lcd_Custom_Cmd(Lcd_CURSOR_OFF);           // Turn off cursor
  Lcd_Custom_Cmd(LCD_CLEAR);
  Lcd_Custom_Out(1, 1, text);
  PORTB.F2 = 1;
  while(1)
    Delay_ms(250);  // One second pause
    Lcd_Custom_Cmd(LCD_SHIFT_RIGHT);
    PORTB.F2 = ~PORTB.F2;
This is my circuit:
change this
to this
  CMCON = 7;             // turn off comparators
  ADCON1 = 0x0F;           // turn off analog inputs
and see what happen
Sorry It doesn't work
I put putt-up res. but I get nothing.
So, when do LED test on PortA and PortE (without putt-up res.)I get sometning unblieveable: LEDs RA0 and RA1 blink but RA2 and RA3 light without blinking.
On PortE, I get RE0 and RE1 blinked but RE2 does nothing.
But the programm works good on Proteus
This is the Code:
//CPU Clock 48MHZ
//PIC18F4550
void main()
  CMCON = 0x07;             // turn off comparators
  ADCON1 = 0xFF;           // turn off analog inputs
  TRISA = 0x00;               // PORTA is output
  TRISE = 0x00;                // PORTE is output
  PORTA = 0xFF;
  PORTE = 0xFF;
  while(1)
    Delay_ms(500);          /* 0.5 second pause */
    PORTA = ~PORTA;
    PORTE = ~PORTE;
Circuit on Proteus:
Try changing all your port reads to latch reads,
so
PORTA = ~PORTA;
becomes
LATA = ~LATA;
Thank You all
:D
I got it due to Your help:
The Problem is that I used PORT instead of LAT
So, thanks for your help special Pommie.
The New code:
void main()
  TRISB = 0x00;                         // PORTB is output
  Lcd_Custom_Config(&LATA,3,2,1,0,&LATE,2,1,0);  // Initialize LCD on PORTB
  Lcd_Custom_Out(1, 16, text);
  PORTB.F2 = 1;
  while(1)
    Delay_ms(300);               // 0.3 second pause
    Lcd_Custom_Cmd(LCD_SHIFT_LEFT);
    PORTB.F2 = ~LATB.F2;
:D
I just wanted to say thankyou for the LAT/PORT hint.
I have been troubleshooting this issue for two long evening/nights now looking for soft and hard errors.... !
thankyou / Ahd71
