problem programing pic16f84A
swh
Hi every body.
I am samuel.
I have two codes writeen in asembly and c. The problem is how to transfer both of this codes together into the microcontroller.One more thing also, is there a problem if I replace the PIC16F84 by PIC16F84A.
thank you for you help.
Do these 2 programs have anything to do with each other? what is the relationship between the 2 ? ...
Strange id to put 2 seperate programs into one pic, more info would be nice.
The two codes written in assembly and in c are suppoed to work together the same job. First the assembly reads a frequency calculate the level changes from 5 to 0. After that the cod written in c compares this levels with the stored ones and drives leds acording to the value of the comparison.
hat is easier if you copy the asm code and paste to c code between
#asm
#endasm
compile the c code again and program for your pic.
if you want to use #include <file> you have to write the c code in form of .h file. That is no a file to run. I don't know how to explain in English. But well, you can try my solution upthere.
If i do so will the assembly language be executed first?
Jou place the #asm directives at the place where the asm should be executed.
For example, you make a function Call_Asm() and in that function you put your asm code using the directive, then the asm code will be called every time you call your Call_Asm() funtion
I get what you mean.But for me it would be easy if there is a way to call the c inside the assembly.
And by the way is there any proboblem if i replace pic16f84 with pic16f84A
the programs were written for pic16f84A.
It makes no difference, the A version of the 16F84 is simply a later silicon revision, and not a FLASH chip like many of the newer A varients.
