Pro pls help me check this program
babboy12345
I cant build this program,got error occur,but the problems is i dono how to corrected it....pls help
LIST P=16F877A
INCLUDE "P16F877a.inc"
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_O
CHK1 EQU 0X21
CNT1 EQU 0CH
CNT2 EQU 0DH
count EQU 020;
org 0x000
nop ;
banksel TRISA
movlw b'00000000';
movwf TRISB;
banksel ADCON1
movlw b'10000000
movwf ADCON1
banksel ADCON0
movlw b'10000001
movwf ADCON0
getAD movlw 007
movwf count
down decfsz count
goto down
bsf ADCON0,GO
wait btfsc adcon0,GO
goto wait
return
start call getAD ; get adc result store at adresh
movlw 0xC8 ;
error here subwf adresh,1 ; adc result in adresh will minus....
btfsc adresh,0 ;...C8 and the answer store at adresh again..
goto start ; if answer in adresh is not 0....then the program will jump to start again...
btfsc adresh,1
goto start
btfsc adresh,2
goto start
btfsc adresh,3
goto start
btfsc adresh,4
goto start
btfsc adresh,5
goto start
btfsc adresh,6
goto start
btfsc adresh,7
goto start
bsf portb
call delay
end
delay MOVLW D'5'
MOVWF CNT2
CON1 MOVLW H'FF'
MOVWF CNT1
DECFSZ CNT1,1
GOTO $-1
DECFSZ CNT2,1
GOTO CON1
RETURN
Try moving the END instruction to the end of the code.
Also, when posting code type
 before it and
after it so that it keeps it's formatting.
i try to put end there....bt still got error..wat u means by (Also, when posting code type
 before it and
after it so that it keeps it's formatting.)???
 before it and
See what happened when you typed it into your post there? You created that blue 'code' block in your post. If you put those tags before and after any source code that you include in yours posts, then it will format the code and make it easier for everybody to read.
Another hint is that you should never just say 'I got an error' without also saying exactly what the error was. There was probably information in the error which would help determine exactly what the error was and why it occurred. That's why error messages are generated.
Regards,
Torben
the error say Symbol not previously defined (adresh)
code:/
LIST P=16F877A
CHK1 EQU 0X21
CNT1 EQU 0CH
CNT2 EQU 0DH
count EQU 020;
org 0x000
nop ;
banksel TRISA
movlw b'00000000';
movwf TRISB;
banksel ADCON1
movlw b'10000000
movwf ADCON1
banksel ADCON0
movlw b'10000001
movwf ADCON0
getAD movlw 007
movwf count
down decfsz count
goto down
bsf ADCON0,GO
wait btfsc ADCON0,GO
goto wait
return
start call getAD
movlw 0xC8
btfsc adresh,0
goto start
btfsc adresh,1
goto start
btfsc adresh,2
goto start
btfsc adresh,3
goto start
btfsc adresh,4
goto start
btfsc adresh,5
goto start
btfsc adresh,6
goto start
btfsc adresh,7
goto start
bsf portb
call delay
end
delay MOVLW D'5'
MOVWF CNT2
CON1 MOVLW H'FF'
MOVWF CNT1
DECFSZ CNT1,1
GOTO $-1
DECFSZ CNT2,1
GOTO CON1
RETURN
end
another error say Missing argument(s)
code:/
LIST P=16F877A
CHK1 EQU 0X21
CNT1 EQU 0CH
CNT2 EQU 0DH
count EQU 020;
org 0x000
nop ;
banksel TRISA
movlw b'00000000';
movwf TRISB;
clrf PORTB
banksel ADCON1
movlw b'10000000
movwf ADCON1
banksel ADCON0
movlw b'10000001
movwf ADCON0
getAD movlw 007
movwf count
down decfsz count
goto down
bsf ADCON0,GO
goto wait
return
movlw 0xC8 ;
subwf ADRESH,1 ; adc result in adresh will minus....
btfsc ADRESH,0 ;...C8 and the answer store at adresh again..
btfsc ADRESH,1
goto start
btfsc ADRESH,2
goto start
btfsc ADRESH,3
goto start
btfsc ADRESH,4
goto start
btfsc ADRESH,5
goto start
btfsc ADRESH,6
goto start
btfsc ADRESH,7
goto start
error here bsf PORTB
call delay
end
delay MOVLW D'5'
MOVWF CNT2
CON1 MOVLW H'FF'
MOVWF CNT1
DECFSZ CNT1,1
GOTO $-1
DECFSZ CNT2,1
GOTO CON1
RETURN
code:/
If you edit your post and put code tags around the code we may be able to see the errors. As it is we are just guessing.
code
LIST P=16F877A
CHK1 EQU 0X21
CNT1 EQU 0CH
CNT2 EQU 0DH
count EQU 020;
org 0x000
nop ;
banksel TRISA
movlw b'00000000';
movwf TRISB;
clrf PORTB
banksel ADCON1
movlw b'10000000
movwf ADCON1
banksel ADCON0
movlw b'10000001
movwf ADCON0
getAD movlw 007
movwf count
down decfsz count
goto down
bsf ADCON0,GO
goto wait
return
movlw 0xC8 ;
btfsc ADRESH,1
goto start
btfsc ADRESH,2
goto start
btfsc ADRESH,3
goto start
btfsc ADRESH,4
goto start
btfsc ADRESH,5
goto start
btfsc ADRESH,6
goto start
btfsc ADRESH,7
goto start
call delay
end
delay MOVLW D'5'
MOVWF CNT2
CON1 MOVLW H'FF'
MOVWF CNT1
DECFSZ CNT1,1
GOTO $-1
DECFSZ CNT2,1
GOTO CON1
RETURN
/code
LIST P=16F877A
CHK1 EQU 0X21
CNT1 EQU 0CH
CNT2 EQU 0DH
count EQU 020;
org 0x000
nop ;
banksel TRISA
movlw b'00000000';
movwf TRISB;
clrf PORTB
banksel ADCON1
movlw b'10000000
movwf ADCON1
banksel ADCON0
movlw b'10000001
movwf ADCON0
getAD movlw 007
movwf count
down decfsz count
goto down
bsf ADCON0,GO
goto wait
return
movlw 0xC8 ;
btfsc ADRESH,1
goto start
btfsc ADRESH,2
goto start
btfsc ADRESH,3
goto start
btfsc ADRESH,4
goto start
btfsc ADRESH,5
goto start
btfsc ADRESH,6
goto start
btfsc ADRESH,7
goto start
call delay
end
delay MOVLW D'5'
MOVWF CNT2
CON1 MOVLW H'FF'
MOVWF CNT1
DECFSZ CNT1,1
GOTO $-1
DECFSZ CNT2,1
GOTO CON1
RETURN
when you look at the error message, it also show you the line number
Ex: Warning[209] C:\ASM_PROG\TEST.ASM 23 : Missing quote
where 23 is the line number. In your case it's the BSF PORTB line.
You'll also have an "Symbol not previously defined (delay)" because your END statement is before the end of you program.
this section
		banksel TRISA
		movlw b'00000000';
		movwf TRISB;
		clrf PORTB
PORTB is not in the same BANK as TRISB, so you'll have to fix it.
What I suggest is to have a look at the datasheet, set register in BANK0, then move on BANK1 and so on
this section at the top of your code
wait
        btfsc ADCON0,GO
		goto wait
		return
once it will hit the RETURN.. it return where as it haven't been called before? Stack underflow :( So, OR you move this routine elsewhere, OR you add a GOTO Start before getAD label.
count EQU 020;
You should make sure if it's correct, same for other GPRs.
...  _PWRTE_O
have to be _PWRTE_ON
There's also potential issue with this
here    bsf PORTB <--- missing something here
		call delay
delay
		MOVLW D'5'
		MOVWF CNT2
What happen after the Call Delay, yup it process the delay routine again... and will hit another RETURN, another Stack underflow.
HTH
		banksel TRISA
		movlw b'00000000';
		movwf TRISB;
		clrf PORTB
(PORTB is not in the same BANK as TRISB, so you'll have to fix it.)
can any1 give me a solution for it pls
