prevent circuit from oscillation
Jony130
Active Member
Hi.
Can you hale my prevent this constant current source circuit from oscillation.
Why this circuit even start to oscillate?
Maybe the circuit is bad?
  • Draft77.asc
    Draft77.asc
Add a 100pf cap from output to (-) of U1.
Break connection from U2 out to U1 in(-). Now add 10k resistor to get the connection back.
The new RC slows down the error amp U1. It ts too fast and too much gain.
THX I try this tomorrow
Here is a much simpler circuit:
But I need a circuit with low Rr voltage drop (Vcc = 5V) and with high Vin voltage to set the current (from 0 to 4V).
If you use an op amp with rail-to-rail I/O, it should work.
If your collector resistor is really 100Ω, and your maximum current is 4V/10Ω=400mA, then you will need a collector supply voltage much higher than 12V.
