powering 12v dc motor from Lipo for respirator.
AnonEmiss
So,,,
I have decided that I need a powered respirator for varnishing (moisture cured polyurethane contains isocyanate, not a good smell). I made one using a full face snorkeling mask and air blower (thanks Youtube) tested it using a bench power supply and it works great (so far, so good).
Now I want to make it portable:
I have a good supply of tested 18650's that while not new, are good enough for this job (as per photo). I want to make 3 power packs using a 4s3p battery layout (I have a home made spot welder to make the packs up). I could also go to a 5s3p layout, but would prefer not to.
I was intending to use the following:
- BMS (1 per pack): 4s BMS
- Option to charge via USB (only need one): 4s USB charger
- Battery level indicator (really only NEED one, but I might put 1 per pack): Power level indicator
- I already have a DC-DC buck converter to get the required 12v DC-DC buck converter
- And finally a motor speed controller (PWM I assume): PWM speed control
During testing I found running the pump @ 12v it was too powerful, so need to reduce the airflow (hence = speed controller)
I realise that I can use the DC-DC converter to reduce the voltage, but the adjusting screw is REALLY small, and I want to use an easy-to-get-at control, plus there is a risk that I might go above the rated 12v to the motor, so just use the buck converter to set a regulated voltage (12v) and use a motor controller after that.
My Question(s):
If I am going to use the above speed controller do I even need the DC-DC converter, and will there be any 'interference' using a PWM motor controller 'Downstream' of the buck converter?
The preferred BMS has a discharge cut-out at 2.55v - what if I wanted to set the cut-out at 3.25v (14v for the pack), how could I do that?
I know these are basic questions (and yes I am totally noob) - but that should mean they are easy for you knowledgeable people to answer (I hope).
I have attached some pictures to assist with 'context'
End of charge conservative at CV is I< C/10 or < 10% of CC rate. Aggressive is < 3% of CC rate. The aging rate accelerates above 3.8V during charging and more rapidly above 4.0V and even more above 4.1 as this causes self-heating which is an accelerator of aging.
There are different profiles for Lithium chemistry, safety, speed-charge and long life cycles (>> 5000) that depend on how much time you spend below 3V and above 3.8V and the rise in the junction temperature has a common Arrhenius Effect every 10'C rise above room temp.
Just beware, there are tradeoffs and safety concerns if unattended and choice of cutoff voltage for charge and discharge are big factors.
Common is 10% CC until Vbat > 3V then CC until CV then cutoff when Ibat< 3% or 5% or 10% CC (depending on OEM) with no external load! Otherwise, both charge and battery current, must be measured simultaneously.
Did you notice anything uncertain from the statement "For these reasons, the charger should control the final voltage to within ±50 mV of 4.1 or 4.2 V and be able to detect when the battery is fully charged" ? Why 4.1 or 4.2?
The capacity is slightly improved with 4.2V end of CV cutoff, but life expectancy is compromised due to the increased self-degradation when above 4.0V. I once plotted the data from the Battery University site and when only using 50% of the rated capacity and also limiting CV to 4.0V before cutoff you might have 90% capacity thus if you stop using the battery at 40% you have only used 50% of the capacity yet the total Ah times N cycles can be 10 times more energy used than following the manufacturer's specs. Most users just want the longest flight time or longest mobile time between charges and don't think about the long term. Besides, they usually don't have the option to use a conservative charge profile until iOS recently does this automatically based on your usage and I recall Lenovo laptops once had a setting for the situation where a laptop was plugged in all the time, so the capacity was kept at 66% or 75% (?) just like the factory ships them for the longest shelf life.
Now, this was anecdotal memory on conventional Lithium-ion and Lithium Polymer cells and not LiFePO4 cells.
Series battery packed cells must be extremely well-matched when new because there is a positive feedback mechanism that degrades the weakest cell faster than the rest in series. Whereas in parallel, the strongest cell with the lowest ESR supplies or receives more current, which can ages the battery until the ESR matches the others even if the Capacity in kilofarads is different. Thus, conservative 0.5C charge rates are preferred to reduce aging of the weakest series cell.
Just because they say you can charge 70% of the battery capacity in x minutes, doesn't mean you should! There is always a tradeoff with aging and aggressive charging.
I have also charged Li Ion batteries with a digital lab supply on occasions and even primary EverReady Alkaline and Lithium Coin cells in a pinch at very conservative currents to avoid thermal rise just to eke out a tiny more charge storage life.
Unlike lead-acid batteries where the terminal voltage is not necessarily a good indicator of state of charge, li-ion batteries can have their state of charge determined by terminal voltage alone when the current through the cell is low enough to render voltage drops across the internal cell resistance negligible. The supply will stop putting out power when the cell reaches 4.2v (fully charged) since it will be set to that voltage and there will no longer be a potential difference.
This article seems to agree with me:
Lead-acid voltage can be accurate in some situations with capacity 0 to 100% from 11.5 to 12.5V if preloaded after charging to bleed off some secondary charge layer within a minute at room temp. Otherwise the voltage can float at 12.8V for a while after charging. Lead Acid also have much higher ESR. The CCA rating is a drop from 12.5V to 7.5V at 0 deg. Although your car might never demand that unless the engine was -30 'C and the battery was kept warm with a 100W blanket.
Tony from WinterPeg ;)
( but now near Toronto)
I am aware of how li-ions are charged.
I'm not saying you're wrong, but li-ions are charged by constant current and then constant voltage once they get close to the full charge voltage, which is exactly what a power supply would do if you set the voltage to the correct value (4.2v for a single cell) and set the current limit to a safe value. Of course balancing is required for multiple cells in series, but if that is taken care of why should one not charge batteries with a power supply? I have done this before several times without experiencing any issues. Please tell me what I'm missing here.
I think with many almost matched batteries, you must take a more conservative charge profile and choose the cutoff threshold to prevent the weakest cell from accelerated aging. . Without that you can consider CC to CV at 3.8V which takes longer at this conservative profile for the secondary storage capacitance to charge up than to overvoltage charge at 4.1 then cutoff at C/10 current.
To make a good pack both the equivalent Capacitances should be matched to avoid the weak cell acceleration phenomena. Some techs salvage EV packs and match the best to repackage using just float voltage after charge, but this is not the most accurate way. The capacity = 1C= Ah rating of cell is relayed but not the same as the capacitance C in Farads which is close to 10k Farads for a new 18650 cell with and ESR that is inversely related to the “C” charge rate like 1C, 2C, 4C, 10C, 20C and this degrades with aging meaning the minimum ESR rises when charged.
Regarding the motor speed control, I wonder if modifying the cheap buck regulator to have a soft start and replace the pot control to control the motor speed directly. I hope the PWM buck speed controller does not introduce any harmonic mixing issues with the cheap adjust DCDC converter. An integrated ESC, Electronic Speed Controller might be a better approach if that is the case.
How would you modify the buck converter for a soft start? I'm wondering whether a capacitor placed between the wiper on the voltage adjust pot and ground would cause the voltage going into the control input on the buck converter IC to ramp up slowly causing the output to also ramp up slowly.
Remember that is likely to be a feedback circuit - the wiper voltage will be compared to a reference.
If that is so, holding that down would cause it to go to maximum voltage.
A capacitor or extra variable resistor between the top of the pot and wiper would hold the voltage down.
XL4015. This DCDC converter cannot do it. RJ is correct. I suggest you use a DCDC down-converter with enough capacity to handle 20A but with an adjustable current limiter such as this one with twin heat sinks. Consider a small fan if it gets hot. Then you can use a bigger battery pack and won’t need the PWM regulator either. But you will want to avoid overloading the battery too with a suitable pack.
this
this
I am inclined to agree, the XL4015 is only rated @ 5Amps (and I suspect that is a momentary rating, with a continuous rating of a lot less, I will need to check).
Getting a higher rated buck converter seems to be a very good idea (and they are cheap-as-chips). I seriously doubt that I will need a fan, just ensure good air-flow across the heat sinks(s) will be sufficient for even extended use.
I still want to able to have a simple speed control (rather that trying to turn a tiny screw on the buck converter) would adding an extra variable resistor (pot) to the voltage control pot (of the Buck converter) still be effective, or do I need to be concerned that the constant current (set by the 2nd pot) would then also need adjusting ?
This thread seems to have gone into a detailed discussion about LiPo charging which, while valuable, is covered in extensive flame-wars in many other threads already.
I am still very interested in the discussion regarding the batteries however as I have nearly 450 Panasonic NCR18650B cells that are in excellent condition.
Of the ones that I have capacity tested they are all >95% of original rated capacity, many of them have tested (slightly) better than the data-sheet specs for new cells.
I basically got these for $0.25 each (NZ$ so US$ =$0.14 / each).
I don't currently have a project for them (other than maybe a few for this,,,,) but at that price was willing to buy them anyway.
Problem with these cell is the low discharge rating (6.7A - I think) so no good for anything that is high drain (at least without putting LOTS in Parallel) but great capacity (3250mAh)
You may replace the 10 turn trumpet for voltage with short twisted leads to an external single turn pot. The current limit trimpot will be useful as a soft start limiter that you can set and forget from the 12V setting.
