thank you eric.... But do yu know anything about hall effect sensors?looking at the d/s i would imho say its not suitable, perhaps some member who has used the device may help.
i would like to know how fast the magnet is pushed/pulled in and out of the coils.... Using a hall effect sensor
i would precisely need to know the magnets motion as thats what the project is about...... im emulating the magnet to be a human limb..... and the limbs motion if a magnet was attached to it ... generates how much power.......You could get that data from observing the voltage produced by the detector coil, using a scopes X timebase.
it really helped me a lot thank you .....If it was just a lab test rig, I would use a scope in the way I suggested, you could easily work out the motion of the magnet, the average/peak power and points of maximum energy generation from the scopes waveform.
You could make drive and frequency adjustments in real time while you observe the waveform.
When you do the lab tests, use a load resistor across the generator coil, without a load the waveforms will be misleading.
The load resistor should be close in value to the actual load in the final design.
