3-way switch is a 3-position switch wired to connect the bridge pickup, neck pickup, or both. It appears that the pickups will be connected in parallel.You need to explain this better for people who don't play guitar (me) and haven't the foggiest idea what you mean. How does the 3-way traditional toggle switch work and what do you propose replacing it with?
Yes, it will work fine, as long as you have switches it does not matter to the electronics how you operate them.I'm working on a guitar and I'd like to use two push/push potentiometers as on/off switches for my (two) pickups instead of the traditional 3-way toggle switch, will this work effectively?
Both.or is the third way both
Thanks!
So that's decided - definitely pull to mute!It can easily be bumped during a performance.
Or, one switch changeover and the second switch linking the two pickups - so no "dead" combination at all??
