Ports won't display
jasbertfalutine
Hi everybody,
i have tried to write a simple program to display on led.
i used the template source and the linker script from microchip but i keep getting an error on stack underflow at address 0x00005 of my 16f877a chip
Is that all? - that seems lacking in many of the required lines?, such as setting the config fuses, specifying the processor and include file etc.
Also, 'incf portb' isn't complete, and probably isn't a good choice anyway?.
I never use either MPLAB, or the simulator, I just use MPASMWIN, the assembler part of MPLAB - and test the programs on hardware.
But how about correcting the 'incf' line?.
jasbertfalutine said:
what could i use instead of "incf portb" command
You could try adding all the parameters to it?, what destination are you sending the result to?. I can't even remember what the default is?, but it's important to add the destination to the end of such commands - in this case ', f' so the answer is written back to the port.
However, in this case, the rapid 'read, modify, write' might be a problem?, and I would suggest incrementing a GPR instead, then moving it to the port.
banksel trisb
movlw b'00000000'
movwf trisb
                       ;<<< misssing banksel portb here
clrf wreg
clrf portb
start incf portb
goto start
end
Hate to tell you but you are still in bank1, whereas portb is in bank0.
