Triode
I'm planning on trying out this design (By Eugene Blanchard)
I have most of the parts, but I'm going to have to order the transistors and the diodes. Its all specified except the mosfets. The first one I build will be wired up to control lego motors. The best site Ive found so far for their ratings is here. At 9 volts the maximum stalled current of the motor types I'm going to use will be 700 mA.
Since I'm not real experienced with this I want to check that I'm choosing good mosfets, I'm pretty clear on the rating, they say what current and voltage they can handle. But I've found with some the mosfets, particularly P type, the RDS (on) is fairly high for the low current ones. Now intuitively one assumes that you want the smallest that will work for energy efficiency, that would be the case with some relays, but if I get a to-220 p channel mosfet that handles 1 amp, the best I can find is about 2 ohms RDS, If I go up to 13 amps, I can find one thats just 0.009 ohms RDS, and it isnt even that expensive, 91 cents (heres a transistor of that description, datasheet). So from what I've learned so far, this would be a good choice, its go a wide factor of safety over the 700ma max im going to draw, and it should eat up a lot less power as heat because of its low RDS. While I probably misunderstand something here, I can learn from you guys telling me what I got wrong. I'll come back and put the datasheets for the specific P and N type mosfets I plan to use once I get them picked out, for now I want to make sure I've got the theory right.
Heres the ones I've picked out at the moment:
FQP8P10 100V P-Channel QFET (mouser page) (Data sheet)
FDP55N06 SINGLE N-CH 150V ULTRAFET TRENCH (mouser page) (Data sheet)
as far as I know they should work fine, and be fairly efficient, but even though the $8 it'll cost for the amount I'm going to order isnt much, it would get annoying if I have to pay that much and wait repeatedly to get it right, so I just want to make sure.
