shezza84
Do I need a diode after the PIR sensors to stop voltage from entering the PIR switch backwards? In the schematic, of course one of the diodes Im asking about would be flipped horizontally...
If I do, will I have 2.4v dropped by the diodes alone? Do I need to have higher than 12v powering the circuit to make up for the voltage loss being the LEDs run off 12v roughly... or is this loss only beyond each diode? Does every diode drop voltage? Or only the ones blocking the voltage? If someone could simplify it a bit, would really appreciate it!
