PIC18F4550 USART problems.
Vizier87
Active Member
Hello guys,
I've been using PIC18F4550 which is connected to a PC via RS232 with a USART 8-bit configuration. For transmission of 8-bit data with a baud rate of 2400 bps is good, but I've been having problems in receiving data from a PC because the programming keep polling the RCIF where when data is received, RCIF=1, but the problem is that RCIF never gets to be 1.
Here is the code:
Main:
setf count
clrf TRISB
movlw b'10000000'
movwf TRISC
movlw 0x00
movwf TRISD
;initialize uart
movlw b'01001010'
movwf BAUDCON
movlw 0x22
movwf SPBRG
movlw 0x08
movwf SPBRGH
;2400 baudrate
bcf TXSTA , SYNC
bsf RCSTA , SPEN
bsf RCSTA , CREN
loop btfss PIR1 , RCIF
     goto $-1
btfsc RCSTA , FERR
goto  clearf
btfsc RCSTA , OERR
goto  clearo
movf  RCREG , W
movwf PORTB
;clrf PORTB
goto loop
clearf bcf RCSTA , CREN ; clear framming error
	bsf PORTB , 7
       goto loop
clearo bcf RCSTA , CREN ; clear overrun error
        bsf PORTB , 6
	goto loop
Sometimes the data received is not accurate.
Please give some advice.
Thanks.
You are using a 18F chip, so $-1 does not work as it would on a 16F chip, as the 18F instructions are in 2 or 4 bytes, so you must use $-2.
Using a Goto avoids any such migration problems.
Looks like Wp100 found your problem. Just change goto $-1 to goto loop.
