PIC18f4520 circuit problem??
haowhaow
hi, im newbie in programming.....
im using MPlab to simulate my project.....
im using Hi tech compiler....when i start simulation....
i get an error of " [pic18] illegal FOSC bits (0b1010) in CONFIG1H "...
may i know what is the problem??
here is my coding ....
#include <htc.h>
#include <math.h>
#include "lcd.h"
//Chip Settings
__CONFIG(1,0x0200);
__CONFIG(2,0X1E1F);
__CONFIG(3,0X8100);
__CONFIG(4,0X00C1);
__CONFIG(5,0XC00F);
//Simple Delay Routine
void Wait(unsigned int delay)
for(;delay;delay--)
__delay_us(100);
//Function to Initialise the ADC Module
void ADCInit()
//We use default value for +/- Vref
//VCFG0=0,VCFG1=0
//That means +Vref = Vdd (5v) and -Vref=GEN
//Port Configuration
//We also use default value here too
//All ANx channels are Analog
ADCON2
*ADC Result Right Justified.
*Acquisition Time = 2TAD
*Conversion Clock = 32 Tosc
ADCON2=0b10001010;
//Function to Read given ADC channel (0-13)
unsigned int ADCRead(unsigned char ch)
if(ch>13) return 0; //Invalid Channel
ADCON0=0x00;
ADCON0=(ch<<2); //Select ADC Channel
ADON=1; //switch on the adc module
GODONE=1;//Start conversion
while(GODONE); //wait for the conversion to finish
ADON=0; //switch off adc
return ADRES;
void main()
//Let the LCD Module start up
Wait(100);
//Initialize the LCD Module
LCDInit(LS_BLINK);
//Initialize the ADC Module
ADCInit();
//Clear the Module
LCDClear();
//Write a string at current cursor pos
LCDWriteString("Temperature:");
LCDWriteStringXY(4,1,"Degree C");
/* while(1)
unsigned int val; //ADC Value
unsigned int t; //Temperature
val=ADCRead(0); //Read Channel 0
//t=round(val*0.48876);//Convert to Degree Celcius
t=round(val*100);
LCDWriteIntXY(0,1,t,3);//Prit IT!
Wait(1000);
while(1)
unsigned int val;
//voltage= ((val)/1100)*5;
//The above formula give voltage in Volts, to get Voltage in mili Volts (mV) we must multiply it with 1000, so
//voltage=((val)/1100)*5*1000); //Voltage is in mV
//since (1/220)mV = 1 degree, to get temperature we must divide it by 1/220, so
//t=((val)/1100)*5*1000*220); //t is in degree centigrade
//simplifying further we get
//t=((val/1100)*1100000);
//t=(val*1000);
//we round off this value, so
t=round(val*1000);
Wait(1000);
below i have attach my problem ....hope that anyone here can help me solve it~appreciated it much!!
Your config settings are invalid. See attached for valid config settings and then enter them in the form,
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO67
NEVER use stupid hex values in config settings and then expect anyone to help debug.
Edit, looking at the pdf, the above will probably be what you need. Just copy and past it instead of all the config lines.
oh....i get what u mean d....hehe...anyway thankz
but now my lcd display can't display any value(js show "0)." ) ....what problem again??
im using HI tech compiler...can i still set the code as what u had teach me???
