Pic18f452 tmr0 & interrupt problems
BoBX
Hello,everybody.I write a program to measure the input signal frequency by using an TMR0 interrupt and A function to display it on a LCD.But my TMR0 interrupt function does not send counter varaiable[cntr] to my
displaying funtion or maybe not worked well,because I have only ; FRQ.= 00000 HZ on my LCD,[I test my funtion of FRQ. displaying by writting cntr=45678,then it displayed it on my LCD.So ,my Tmr0 interrupt function is not worked prioperly.].
At the following are myTMR0 interrupt function in two way but does not worked none of them.
Would you please help me to correct it?
My TMR0 interrupt functions;
PIC18F452,XTAL;20MHZ
1.way 1;
FREQUENCY MEASURMENT Interrupt.
this program writes the frequency of
the input signal on the RB1/INT1 pin.
//PORTB,RB1,IN : Counter Input.
//RB1 Interrupt.
void frqint(unsigned long int cntr){
extern unsigned long int cntr;//Number of RB1 transition.
extern unsigned int ovrflw;//Number of timer0 overflows.
extern unsigned char frq;
INTCON.INT1IE=1;//Enables INT1 external interrupt.
T0CON = 0b11011000;//No prescaler.[RBPU INTEDG T0CS T0SE PSA PS2 PS1 PS0.].
cntr =0;//Clear counters;the number of RB1 transition.
ovrflw =0;//Clear the number of timer0 overflows.
INTCON3 =0b00001000;//INT1IE,INT1IF enabled.
while(ovrflw < 65223){//Wait 1 second.
T0CON.TMR0ON=1;//Enables Timer0;ON.
if(INTCON.INT1IF){
cntr++ ;//Inc.transition counter.
INTCON.INT1IF=0;//clear interrupt flag to enable next call.
else if(INTCON.TMR0IF){ //TIMER 0 overflow.
ovrflw++ ;//Inc.overflow counter.
INTCON.TMR0IF=0;//clear interrupt flag to enable next call on overflow.
INTCON.INT1IE=0;//Disables INT1 external interrupt.
T0CON.TMR0ON=0;//Disables Timer0;OFF.
2.way2;
//RB1 Interrupt.
INTCON=10100000;//Enables the TMR0 overflow interrupt TMR0IE,and global interrupt GIE.
INTCON2.RBPU=1;//Enable PORTB pullups.
TMR0H=0X7;//For 1 sec.TMR0 interrupt;65223.
TMR0L=0XFE;
T0CON=10000011;//16-bit mode,1:16 prescaler,Timer0 clock input comes from
//prescaler output,Increment on low-t0-high transition
//T0CKI pin, internal instruction cycle clock[CLKO],Timer0 ON.
T0CON.TMR0ON=1;//Turn the TMR0 ON.
do{
if(RB1_bit) cntr++ ;//Inc.transition counter.
}while(!TMR0IF);
T0CON.TMR0ON= 0;//Stops TMR0;turn TMR0 OFF.
INTCON.TMR0IF= 0;//Clears TMR0 overflow interrupt flag bit for the next call.
INTCON.TMR0IE= 0;//Disables TMR0 overflow interrupt Enable bit.
Thanks,:confused:
Why do you not just use the RA4 pin and just enable the timer then just read the timer count after 1 second?
This is what I do..
set up a delay of 1s (loop) and enable the timer before the delay and read after the delay..
Cheers Ian
