hi
i have maneged to build a template file for the PIC18F24J10 and i want to add more lines of code (to follow) to this file so it runs as it says in the document AN1076
; This file is a basic template for assembly code for a PIC18F24J10. Copy *
; this file into your project directory and modify or add to it as needed. *
; The PIC18FXXXX architecture allows two interrupt configurations. This *
; template code is written for priority interrupt levels and the IPEN bit *
; in the RCON register must be set to enable priority levels. If IPEN is *
; left in its default zero state, only the interrupt vector at 0x008 will *
; be used and the WREG_TEMP, BSR_TEMP and STATUS_TEMP variables will not *
; be needed. *
; Refer to the MPASM User's Guide for additional information on the *
; features of the assembler. *
; Refer to the PIC18FXXJXX Data Sheet for additional *
; information on the architecture and instruction set. *
; Filename: *
; Date: *
; File Version: *
; Author: *
; Company: *
; Files required: P18F24J10.INC *
LIST P=18F24J10, F=INHX32 ;directive to define processor
#include <P18F24J10.INC> ;processor specific variable definitions
;Configuration bits
;Microchip has changed the format for defining the configuration bits, please
;see the .inc file for futher details on notation. Below are a few examples.
; Oscillator Selection:
CONFIG FOSC = HS ;HS oscillator
;Variable definitions
; These variables are only needed if low priority interrupts are used.
; More variables may be needed to store other special function registers used
; in the interrupt routines.
UDATA
WREG_TEMP RES 1 ;variable in RAM for context saving
STATUS_TEMP RES 1 ;variable in RAM for context saving
BSR_TEMP RES 1 ;variable in RAM for context saving
UDATA_ACS
EXAMPLE RES 1 ;example of a variable in access RAM
;Reset vector
; This code will start executing when a reset occurs.
RESET_VECTOR CODE 0x0000
goto Main ;go to start of main code
;High priority interrupt vector
; This code will start executing when a high priority interrupt occurs or
; when any interrupt occurs if interrupt priorities are not enabled.
HI_INT_VECTOR CODE 0x0008
bra HighInt ;go to high priority interrupt routine
;Low priority interrupt vector and routine
; This code will start executing when a low priority interrupt occurs.
; This code can be removed if low priority interrupts are not used.
LOW_INT_VECTOR CODE 0x0018
bra LowInt ;go to low priority interrupt routine
;High priority interrupt routine
; The high priority interrupt code is placed here to avoid conflicting with
CODE
HighInt:
; *** high priority interrupt code goes here ***
retfie FAST
;Low priority interrupt routine
; The low priority interrupt code is placed here.
LowInt:
movff STATUS,STATUS_TEMP ;save STATUS register
movff WREG,WREG_TEMP ;save working register
movff BSR,BSR_TEMP ;save BSR register
; *** low priority interrupt code goes here ***
movff BSR_TEMP,BSR ;restore BSR register
movff WREG_TEMP,WREG ;restore working register
movff STATUS_TEMP,STATUS ;restore STATUS register
retfie
;Start of main program
; The main program code is placed here.
Main:
; *** main code goes here ***
;End of program
END
; be needed. *
; Filename: *
; Date: *
; File Version: *
; Author: *
; Company: *
;Configuration bits
UDATA
UDATA_ACS
;Reset vector
CODE
HighInt:
retfie FAST
LowInt:
retfie
Main:
;End of program
END
