PIC18f24J10.asm file
charles01
hi
i have maneged to build a template file for the PIC18F24J10 and i want to add more lines of code (to follow) to this file so it runs as it says in the document AN1076
; This file is a basic template for assembly code for a PIC18F24J10. Copy *
; this file into your project directory and modify or add to it as needed. *
; The PIC18FXXXX architecture allows two interrupt configurations. This *
; template code is written for priority interrupt levels and the IPEN bit *
; in the RCON register must be set to enable priority levels. If IPEN is *
; left in its default zero state, only the interrupt vector at 0x008 will *
; be used and the WREG_TEMP, BSR_TEMP and STATUS_TEMP variables will not *
; be needed. *
; Refer to the MPASM User's Guide for additional information on the *
; features of the assembler. *
; Refer to the PIC18FXXJXX Data Sheet for additional *
; information on the architecture and instruction set. *
; Filename: *
; Date: *
; File Version: *
; Author: *
; Company: *
; Files required: P18F24J10.INC *
LIST P=18F24J10, F=INHX32 ;directive to define processor
#include <P18F24J10.INC> ;processor specific variable definitions
;Configuration bits
;Microchip has changed the format for defining the configuration bits, please
;see the .inc file for futher details on notation. Below are a few examples.
; Oscillator Selection:
CONFIG FOSC = HS ;HS oscillator
;Variable definitions
; These variables are only needed if low priority interrupts are used.
; More variables may be needed to store other special function registers used
; in the interrupt routines.
UDATA
WREG_TEMP RES 1 ;variable in RAM for context saving
STATUS_TEMP RES 1 ;variable in RAM for context saving
BSR_TEMP RES 1 ;variable in RAM for context saving
UDATA_ACS
EXAMPLE RES 1 ;example of a variable in access RAM
;Reset vector
; This code will start executing when a reset occurs.
RESET_VECTOR CODE 0x0000
goto Main ;go to start of main code
;High priority interrupt vector
; This code will start executing when a high priority interrupt occurs or
; when any interrupt occurs if interrupt priorities are not enabled.
HI_INT_VECTOR CODE 0x0008
bra HighInt ;go to high priority interrupt routine
;Low priority interrupt vector and routine
; This code will start executing when a low priority interrupt occurs.
; This code can be removed if low priority interrupts are not used.
LOW_INT_VECTOR CODE 0x0018
bra LowInt ;go to low priority interrupt routine
;High priority interrupt routine
; The high priority interrupt code is placed here to avoid conflicting with
CODE
HighInt:
; *** high priority interrupt code goes here ***
retfie FAST
;Low priority interrupt routine
; The low priority interrupt code is placed here.
LowInt:
movff STATUS,STATUS_TEMP ;save STATUS register
movff WREG,WREG_TEMP ;save working register
movff BSR,BSR_TEMP ;save BSR register
; *** low priority interrupt code goes here ***
movff BSR_TEMP,BSR ;restore BSR register
movff WREG_TEMP,WREG ;restore working register
movff STATUS_TEMP,STATUS ;restore STATUS register
retfie
;Start of main program
; The main program code is placed here.
Main:
; *** main code goes here ***
;End of program
END
and the code i want to add is like this
; File: DMX512RecDemo.asm
; DMX512 Receiver
; This file uses a PIC18F24J10 device to receive DMX-512 data and store it
; into a 512 byte receive buffer.
; For demonstration purposes, a selected data slot is written to the
; CCP module. The CCP module is configured in PWM mode and the received
; data adjusts the duty cycle. If a resistor and LED is connected to the
; PWM output, the received DMX data can be visually observed.
list p=18f24j10 ; define target processor
#include <p18f24j10.inc> ; include processor specific definitions
; Configuration bits setup
CONFIG CCP2MX = ALTERNATE ; assign CCP2 output to pin RB3
CONFIG WDTEN = OFF ; To use ICD2 as a debugger disable Watch Dog Timer
CONFIG STVERN = ON ; Reset on stack overflow/underflow enabled
CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing
; mode disabled (Legacy mode)
CONFIG CP0 = OFF ; Program memory is not code-protected
CONFIG FOSC = ECPLL ; EC oscillator, PLL enabled and under software
; control, CLKO function on OSC2
CONFIG FOSC2 = ON ; Clock selected by FOSC as system clock is enabled
; when OSCCON<1:0> = 00
CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
CONFIG IESO = OFF ; Two-Speed Start-up disabled
CONFIG WDTPS = 32768 ; 1:32768
; Constants
#define CHANNEL .510 ; select the receiver slot/channel
; Variables
CBLOCK 0x8
CountH ;16-bit counter
CountL
RxBuffer: .512 ; 512 bytes buffer allocation
ENDC
ORG 0x0
Main
call SetupSerial ; Setup Serial port and buffers
MainLoop
; first loop, synchronizing with the transmitter
WaitBreak
btfsc PIR1,RCIF ; if a byte is received correctly
movf RCREG,W ; discard it
btfss RCSTA,FERR ; else
bra WaitBreak ; continue waiting until a frame error is detected
movf RCREG,W ; read the Receive buffer to clear the error condition
; second loop, waiting for the START code
WaitForStart
btfss PIR1,RCIF ; wait until a byte is correctly received
bra WaitForStart
btfsc RCSTA,FERR
bra WaitForStart
movf RCREG,W
; check for the START code value, if it is not 0, ignore the rest of the frame
andlw 0xff
bnz MainLoop ; ignore the rest of the frame if not zero
; init receive counter and buffer pointer
clrf CountL
clrf CountH
lfsr 0,RxBuffer
; third loop, receiving 512 bytes of data
WaitForData
btfsc RCSTA,FERR ; if a new framing error is detected (error or short frame)
bra RXend ; the rest of the frame is ignored and a new synchronization is
; attempted
bra WaitForData ;
movf RCREG,W ;
MoveData
movwf POSTINC0 ; move the received data to the buffer
; (auto-incrementing pointer)
incf CountL,F ; increment 16-bit counter
btfss STATUS,C
bra WaitForData
incf CountH,F
btfss CountH,1 ; check if 512 bytes of data received
bra WaitForData
; when a complete frame is received
; use the selected CHANNEL data to control the CCP2 module duty cycle
RXend
lfsr 0,RxBuffer ; use indirect pointer 0 to address the receiver buffer
GetData
movlw LOW(CHANNEL) ; add the offset for the select channel
addwf FSR0L,F
movlw HIGH(CHANNEL)
addwfc FSR0H,F
movff INDF0,CCPR2L ; retrieve the data and assign MSB to control PWM2
bra MainLoop ; return to main loop
SetupSerial
; Clear the receive buffer
lfsr 0,RxBuffer
CBloop
clrf POSTINC0 ; clear INDF register then increment pointer
incf CountL,F
btfss STATUS,C
bra CBloop
incf CountH,F
btfss CountH,1
bra CBloop
; Setup EUSART
bsf TRISC,7 ; allow the EUSART RX to control pin RC7
bsf TRISC,6 ; allow the EUSART TX to control pin RC6
movlw 0x04 ; Disable transmission
movwf TXSTA ; enable transmission and CLEAR high baud rate
movlw 0x90
movwf RCSTA ; enable serial port and reception
bsf BAUDCON,BRG16 ; Enable UART for 16-bit Asyn operation
clrf SPBRGH
movlw .15 ; Baud rate is 250KHz for 16MHz Osc. freq.
movwf SPBRG
; Setup PWM module
movlw 0x0c ; configure CCP2 for PWM mode
movwf CCP2CON
; Timer2 control
movlw 0x04 ; enable Timer2, select a prescale of 1:1
movwf T2CON
; PWM period
movlw 0xFF ; 256 x .25us = 64us period
movwf PR2
; init I/O
movlw b'11110111' ; make pin RB3 (CCP2) output
movwf TRISB
return
END
i have added the asm file to the project 18f24j10 and ran the build all function
i got the followin errors and warnings
i dii not change the default asm file which is generated when you run the new project wizard
i am going to put the code which i used on the next post
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\My Project\18F24J10Proj.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F24J10 "C:\Program Files\Microchip\MPASM Suite\Template\Object\18F24J10TMPO.ASM" /l"18F24J10TMPO.lst" /e"18F24J10TMPO.err" /o"18F24J10TMPo_O" /d__DEBUG=1
Error[176] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 47 : CONFIG Directive Error: (setting "STVERN" not found for the processor 18F24J10)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 153 : Found label after column 1. (Main)
Error[116] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 153 : Address label duplicated or different in second pass (Main)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 155 : Found label after column 1. (MainLoop)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 158 : Found label after column 1. (WaitBreak)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 166 : Found label after column 1. (WaitForStart)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 186 : Found label after column 1. (WaitForData)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 194 : Found label after column 1. (MoveData)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 210 : Found label after column 1. (RXend)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 212 : Found label after column 1. (GetData)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 223 : Found label after column 1. (SetupSerial)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 226 : Found label after column 1. (CBloop)
Halting build on first failure as requested.
Debug build of project `C:\My Project\18F24J10Proj.mcp' failed.
Language tool versions: MPASMWIN.exe v5.35, mplink.exe v4.35
Preprocessor symbol `__DEBUG' is defined.
Wed Feb 03 22:27:46 2010
BUILD FAILED
here is the code
;CONFIG FOSC = ECPLL ; EC oscillator, PLL enabled and under software
; Constants
; Variables
CBLOCK 0x8
CountL
ENDC
UDATA
UDATA_ACS
;Reset vector
CODE
HighInt:
retfie FAST
LowInt:
retfie
Main:
ORG 0x0
Main
MainLoop
WaitBreak
WaitForStart
bra WaitForStart
btfsc RCSTA,FERR
bra WaitForStart
movf RCREG,W
andlw 0xff
clrf CountL
clrf CountH
lfsr 0,RxBuffer
WaitForData
; attempted
bra WaitForData ;
movf RCREG,W ;
MoveData
btfss STATUS,C
bra WaitForData
incf CountH,F
bra WaitForData
RXend
GetData
addwf FSR0L,F
movlw HIGH(CHANNEL)
addwfc FSR0H,F
SetupSerial
lfsr 0,RxBuffer
CBloop
incf CountL,F
btfss STATUS,C
bra CBloop
incf CountH,F
btfss CountH,1
bra CBloop
; Setup EUSART
movlw 0x90
clrf SPBRGH
movwf SPBRG
; Setup PWM module
movwf CCP2CON
; Timer2 control
movwf T2CON
; PWM period
movwf PR2
; init I/O
movwf TRISB
return
;End of program
END
It looks as though it doesnt like STVERN config code and it has found more than 1 label for Main.
What is your exact issue / question with this code?
Wilksey
after disabling the lines with the error messages, i ran the build all tool and got warnings only but the program giving me the following warnings and erro on LINKEr SETUP
Clean: Deleted file "C:\My Project\18F24J10TMPo_O".
Clean: Deleted file "C:\My Project\18F24J10TMPO.err".
Clean: Deleted file "C:\My Project\18F24J10TMPO.lst".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F24J10 "C:\Program Files\Microchip\MPASM Suite\Template\Object\18F24J10TMPO.ASM" /l"18F24J10TMPO.lst" /e"18F24J10TMPO.err" /o"18F24J10TMPo_O" /d__DEBUG=1 /c-
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 155 : Found label after column 1. (MAINLOOP)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 158 : Found label after column 1. (WAITBREAK)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 166 : Found label after column 1. (WAITFORSTART)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 186 : Found label after column 1. (WAITFORDATA)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 194 : Found label after column 1. (MOVEDATA)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 210 : Found label after column 1. (RXEND)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 212 : Found label after column 1. (GETDATA)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 223 : Found label after column 1. (SETUPSERIAL)
Warning[207] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\18F24J10TMPO.ASM 226 : Found label after column 1. (CBLOOP)
Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" "..\Program Files\Microchip\MPASM Suite\LKR\18f24j10_g.lkr" "18F24J10TMPo_O" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"18F24J10Proj.cof" /M"18F24J10Proj.map" /W
MPLINK 4.35, Linker
Copyright (c) 2009 Microchip Technology Inc.
Error - section 'HI_INT_VECTOR' can not fit the absolute section. Section 'HI_INT_VECTOR' start=0x00000008, length=0x00000002
Errors : 1
Link step failed.
Thu Feb 04 09:09:11 2010
is this because i have not yet run the programmer software in which case i intend to use the PicKit 3 programmer
i would like to change my output from RB port to RC (CCP1 and CCP2 + TMR1 or TMR0) as a third oscillator output is this going to be a graet task?
