PIC16F877 EEPROM problem
nicknamefrank
I am trying to write into EEPROM. I am using MPLAB IDE.
cblock 0x110 ;bank 2
VALUE
ADDR
endc
movlw "B"
movwf VALUE
movlw 0x00
movwf ADDR
I am basically using the code given in the data sheet
-->Write Function
BSF STATUS, RP1 ;
BSF STATUS, RP0 ;Bank 3
BTFSC EECON1, WR ;Wait for
GOTO $-1 ;write to finish
BCF STATUS, RP0 ;Bank 2
MOVF ADDR, W ;Address to
MOVWF EEADR ;write to
MOVF VALUE, W ;Data to
MOVWF EEDATA ;write
BCF EECON1, EEPGD ;Point to Data memory
BSF EECON1, WREN ;Enable writes
;Only disable interrupts
BCF INTCON, GIE ;if already enabled,
;otherwise discard
MOVLW 0x55 ;Write 55h to
MOVWF EECON2 ;EECON2
MOVLW 0xAA ;Write AAh to
BSF EECON1, WR ;Start write operation
;Only enable interrupts
BSF INTCON, GIE ;if using interrupts,
;otherwise discard
BCF EECON1, WREN ;Disable writes
--->Read
BSF STATUS, RP1 ;
MOVF ADDR, W ;Write address
MOVWF EEADR ;to read from
BSF EECON1, RD ;Start read operation
MOVF EEDATA, W ;W = EEDATA
I assume that W has the data that was just written.
But after calling to write on the LCD, W doesn't contain anything
Does anyone see a problem with this?
Have you tried it in the MPLAB simulator?
I can connect to my PIC and see the results using the LCD. I assumed that it would be sufficient.
I haven't used the simulator, but since this was the most basic write/read operation, I was just curious whether there is an error in the data sheet or something I have missed.
Using the code from the data sheet, the program doesn't even execute anything after the EEPROM operation.
If you use 16F877 (no A prefix)
base on MPlab File registers then addres 0x110-0x11f has no memory
When you write to EEProm it need a time to complete work
default around 10 mSec/write
better put code below to end of write or before read to check if write complete
;bank 3
Ok i assumed that 0x110-0x11f was bank 2.
I have switched the address to 0x30. But from what I see, any code that appear after the write function does not become executed. It seems like the program just gets "stuck" during the write operation.
does that have anything to do with the bank selection?
Try moving your variables into the common area at 0x70-0x7f as I'm unsure what bank you are in when you write "B" etc to them. Also, as mentioned earlier move the test of WR to after the write as otherwise the hardware will still be busy when you do the read.
		cblock	0x[COLOR="Red"]70[/COLOR]
VALUE
ADDR
		endc
		movlw	"B"
		movwf	VALUE
		movlw	0x00
		movwf	ADDR
-->Write	Function
		bsf	STATUS,RP1	;
		bsf	STATUS,RP0	;Bank 3
		bcf	STATUS,RP0	;Bank 2
		movf	ADDR,W		;Address to
		movwf	EEADR		;write to
		movf	VALUE,W		;Data to
		movwf	EEDATA		;write
		bcf	EECON1,EEPGD	;Point to Data memory
		bsf	EECON1,WREN	;Enable writes
		bcf	INTCON,GIE	;if already enabled,
;otherwise discard
		movlw	0x55		;Write 55h to
		movwf	EECON2		;EECON2
		movlw	0xAA		;Write AAh to
		bsf	EECON1,WR	;Start write operation
		bsf	INTCON,GIE	;if using interrupts,
;otherwise discard
		bcf	EECON1,WREN	;Disable writes
[COLOR="red"]		btfsc	EECON1,WR	;Wait for
		goto	$-1		;write to finish[/COLOR]
--->Read
		bsf	STATUS,RP1	;
		movf	ADDR,W		;Write address
		movwf	EEADR		;to read from
		bsf	EECON1,RD	;Start read operation
		movf	EEDATA,W	;W = EEDATA
Thanks I think that will help.
However, I just realized that simply by adding in the code
" BSF STATUS, RP1"
It freezes my entire program. Nothing after that line of code even becomes executed :(
The only way that can cause a problem is if an interrupt comes along. Do you have interrupts running? Can you post a complete file that exhibits the problem?
Apparently it was because of the bank selection.
I needed to change the bank to zero after each write/read operation
BCF STATUS, RP1 ;
BCF STATUS, RP0 ;
and it becomes functional :)
But thank you very much for being helpful
as a side note, how do you guys know so much about these subjects? Especially with different types of PICs and various different languages?
PIC's all use pretty well the same code, and the language here is all just PIC assembler, so it's not much of a problem. PIC's been RISC devices are so simple, you cam learn them in just a few days.
oops for some reason, I just found out that the read function can only read the last entry of the write function.
I stored A in 0x00 B in 0x01 C in 0x02 respectively (by incrementing ADDR)
Then I attempted to read 0x00.
All I get is C.
Does anyone know how that works?
Use your programmer to read back the EEPROM to see if the problem is with the read or write. The problem is most likely bank related. Post your code and I'm sure someone will spot the problem. Post your complete code rather than the bit you think is wrong.
cblock 0x70
ADDR
VALUE
endc
writeEEPROM macro reg, address
 BSF STATUS, RP1 ;
 banksel address
 MOVF address, W
 MOVWF EEADR
 banksel reg
 MOVF reg, W
 MOVWF EEDATA
 ;otherwise discard
 ;otherwise discard
 BCF EECON1, WREN ;Disable writes  bank0
 BCF STATUS, RP1 ;
 BCF STATUS, RP0 ;Bank 0
 endm
 readEEPROM macro address
 BSF STATUS, RP1 ;
 banksel address
 MOVF address, W ;Write address bank2
 BCF STATUS, RP1
 BCF STATUS, RP0
 endm
setID
	movlw	B'00000100'
	movwf	counter
	movlw	0x19
	movwf	ADDR
	repeatID
	call keyRelease
	call keySelect		;takes in a letter
	movwf	VALUE
	call KPHexToChar	;converts to character
	call WrtLCD		;display on LCD
	writeEEPROM VALUE, ADDR	;store the character in EEPROM
	readEEPROM ADDR
	call KPHexToChar
	call WrtLCD
	incf	ADDR, F
	decfsz	counter, F
		goto repeatID
	endSetID
	movlw	0x19
	movwf	ADDR
	readEEPROM ADDR
	call KPHexToChar
	call WrtLCD
	return
this is not the entire code but the code that is most relevant.
If I were to write and read right away, then it works.
But the read function only reads the last data that was written.
You are writing to EEADR in bank zero and so it is not getting changed.
 banksel address
The reason I suggested placing your variables in the common area is so you wouldn't have the pain of constant bank switching. Delete the banksel line and it should work correctly.
