PIC16F877 4x3 keypad
11max11
i have doing a keypad but when i have press any button it will keep sent the data until i have press other....
i want to ask is that any method can let the user press any button will sent one data only??
Nigel's very fine demo' waits until the key is released before testing for a new key. Another method would use a single variable and three instructions to implement a key state latch which allows testing the Zero flag for no key, same key, and new key pressed states.
One method is not necessarily better than another and both methods mentioned can be expanded to provide switch press beep, repeat key, and multiple (shifted) key map tables.
;*  GetKey, a blocking type subroutine, waits for key press and   *
;*  returns a character in WREG from the keypad "map" table       *
        radix   dec
GetKey
        DelayMS(16)             ; delay 16 msecs between scans    |B0
        call    ScanPad         ; scan the keypad                 |B0
        bz      GetKey          ; a new press? no, branch, else   |B0
;  optional key press beep
        bsf     Beep,4          ; do a 16 msec beep               |B0
DoBeep  movf    PORTA,W         ; read port A                     |B0
        xorlw   1<<Spkr         ; toggle speaker bit              |B0
        movwf   PORTA           ; toggle speaker pin              |B0
        DelayCy(Clock/4*1000-6) ; delay 1000 us for 500 Hz tone   |B0
        decfsz  Beep,F          ; done?  yes, skip, else          |B0
        goto    DoBeep          ; loop (toggle Spkr pin again)    |B0
        movlw   high(Map-128)   ; table address hi -128           |B0
        movwf   PCLATH          ;                                 |B0
        movlw   low(Map-128)    ; table address lo -128           |B0
        addwf   Keylat,W        ; add key latch (80..8F)          |B0
        skpnc                   ; carry? no, skip, else           |B0
        incf    PCLATH,F        ; bump PCLATH                     |B0
        movwf   PCL             ; return with map table char      |B0
Map     dt      '0','1','2','3' ; row 0 map                       |B0
        dt      '4','5','6','7' ; row 1 map                       |B0
        dt      '8','9','A','B' ; row 2 map                       |B0
        dt      'C','D','E','F' ; row 3 map                       |B0
;*  ScanPad, 4x4 Keypad              Mike McLaren, K8LH, Nov '07  *
;*      RB3 RB2 RB1 RB0      <> requires PORTB weak pull-ups      *
;*  RB4 [0] [1] [2] [3]      <> returns Z=0 for a "new" key only  *
;*  RB5 [4] [5] [6] [7]      <> returns Z=1 when no keys pressed  *
;*  RB6 [8] [9] [A] [B]         or if same key is still pressed   *
;*  RB7 [C] [D] [E] [F]      <> isochronous (77 cycles per call)  *
;*  the Keylat key state latch contains pressed key value 80..8F  *
;*  or 0 (no key pressed).  clear Keylat after getting a new key  *
;*  from ScanPad for "repeat key" operation (see example).        *
;*  26 words, 77 instruction cycles (isochronous)                 *
ScanPad
        movlw   TRISB           ; address of TRISB in bank 1      |B0
        movwf   FSR             ; setup indirect access           |B0
        movlw   b'11110111'     ; setup column 0 (RB3) as output  |B0
        movwf   INDF            ; pseudo "movwf TRISB"            |B0
        clrf    Column          ; set keypad column offset = 0    |B0
        movlw   0               ; clear W                         |B0
        setc                    ; must shift 1 bits into TRISB    |B0
ScanCol
        clrf    PORTB           ; set column pin low and Z=1      |B0
        btfss   PORTB,4         ; row 0 press? no, skip, else     |B0
        iorlw   0x80            ; indicate key 0, 1, 2, or 3      |B0
        btfss   PORTB,5         ; row 1 press? no, skip, else     |B0
        iorlw   0x84            ; indicate key 4, 5, 6, or 7      |B0
        btfss   PORTB,6         ; row 2 press? no, skip, else     |B0
        iorlw   0x88            ; indicate key 8, 9, A, or B      |B0
        btfss   PORTB,7         ; row 3 press? no, skip, else     |B0
        iorlw   0x8C            ; indicate key C, D, E, or F      |B0
        skpz                    ; key press? no, skip, else       |B0
        iorwf   Column,W        ; W = 80,84,88,or 8C + Column     |B0
NextCol
        incf    Column,F        ; increment column offset, 0..3   |B0
        rrf     INDF,F          ; setup TRISB for next column     |B0
        skpnc                   ; are we done? yes, skip, else    |B0
        goto    ScanCol         ; scan the next column            |B0
ScanLat
        xorwf   Keylat,W        ; same as last key state latch?   |B0
        skpz                    ; yes, skip with Z=1, else        |B0
        xorwf   Keylat,F        ; update key state latch          |B0
        return                  ; Z=0 only for a "new" key press  |B0
