Pic16f84a and pic16c54
Both are antiques, but even the long obselete F84 is a better chip than the C54 - it should be fairly easy to port a C54 program to the F84, or even better a modern replacement for the 84.
Replacing a 16C54 by a 16F84 may not be "so easy" due to the stack and program counter width ... ( ahaaaaaa ...)
Much better use a newer 16F54 ... especially raised for compatibility ...
Alain
No problem at all, as the 14 bit series are upwards compatible - the other way would be VERY different though.
Hi, Nigel
I have here a nice old DCF project from elektor ( Berliner Uhr ) for you to translate, if you want ...
Dozens of "not too bad" programmers have quitted ... but the original works fine !!!
I join it for the game ...
Alain
  • BRLNUHR.ASM
Hi, Nigel
Problems arise with the subs addressing ... as the Stack is only 2 level deep, programmer used nice tricks ... and when porting to a wider PC chip ... bits truncature ( I suppose ) used are no more truncated ...
so addressing becomes false ...
from there to fine running, no one found the right way ... to that day ...
Alain
