PIC16f628a , Timer1 and seven segments
mabauti
Hello everybody:
I'm having a this problem (see attached pics) using pic16f628's timer 1, when applied to a seven segments display.
As you can see in the second pic , the segments A and G don't show up. In the first pic I'm using a different program . Here's the current program :
; Timer using PIC16F628
	list      p=16f628A            ; list directive to define processor
	#include <p16f628A.inc>        ; processor specific variable definitions
	ERRORLEVEL	0,	-302			;suppress bank selection messages
	__CONFIG _CP_OFF & _WDT_OFF & _BOREN_OFF & _PWRTE_OFF & _MCLRE_OFF & _LVP_OFF & _INTOSC_OSC_NOCLKOUT
	cblock 	0x20 	;start of general purpose registers
		w_temp      ;auxiliary for interrupt service
		status_temp
		J 			; auxiliary variables
		K			;
        M           ;
		N			;
		Dig1		; Digit number one on displays
		Dig2
    	Dig3
	    Dig4
	endc
;===========================  MAIN  =========================
;==========================  PROGRAM  =======================
 	org  0x00             ; processor reset vector
    goto Main
	org	 0x04							; Vector de interrupción.
	goto InterruptService
Main:
	movlw	0x07				;Turn comparators off and
	movwf	CMCON				;enable pins for I/O functions
;------ Ports configuration
   	bsf 	STATUS, RP0		;select bank 1
   	movlw 	b'00000001'		;set PortB <1:7> all outputs, PB0 as input
   	movwf 	TRISB
	movlw 	b'00111100'
	movwf	TRISA			;set PortA <2:5> inputs, <0:1,6:7> outputs
    bsf     PIE1,0          ; TMR1 Overflow Interrupt Enable bit
	bcf		STATUS,RP0		; select bank 0
	clrf	PORTA
    movlw   b'00111100'     ;disables timer b0, internal clock b1, enable oscillator b3
    movwf   T1CON           ;prescale 1:8 b5-b4
	;bsf		PORTA,4			;two points clock
	movlw  00h		; initialize counter
	movwf  Dig1
	movwf  Dig2
	movwf  Dig3
	movwf  Dig4
    movlw  b'11000000'
    movwf  INTCON   ;enable global AND peripheral interrupts
    bsf    T1CON,0  ;start timer
Main_loop:
 call Display
 goto Main_loop
; led conversion lookup table
led7
; in:  number in W
; out: 7-seg code in W in format B'xgfedcba'
	andlw   B'00001111'
	addwf   PCL,f
; format 		B'agfedcbx'
	retlw	B'10111110'		;0
	retlw	B'00000110'		;1
	retlw	B'11011010'		;2
	retlw	B'11001110'		;3
	retlw	B'01100110'		;4
	retlw	B'11101100'		;5
	retlw	B'11111100'		;6
	retlw	B'10000110'		;7
	retlw	B'11111110'		;8
	retlw	B'11101110'		;9
;	do some time by executing nested loops
shorttime:
    movlw   D'14'
    movwf   J
jloop:
	movlw	D'255'	; w = 255 decimal
	movwf	K		; K = w
kloop:
	decfsz	K,f		; K = K - 1 , skip next if zero
  	goto kloop
    decfsz J,F
    goto jloop
 return
Display:
    movlw   D'17'   ; D'17'
    movwf   M
mloop:
 movf Dig1,W
 call led7
 movwf PORTB
 bcf  PORTA,7
 bsf  PORTA,0
 call shorttime
 movf Dig2,W
 call led7
 movwf PORTB
 bcf  PORTA,0
 bsf  PORTA,1
 call shorttime
 movf Dig3,W
 call led7
 movwf PORTB
 bcf  PORTA,1
 bsf  PORTA,6
 call shorttime
 movf Dig4,W
 call led7
 movwf PORTB
 bcf  PORTA,6
 bsf  PORTA,7
 call shorttime
 decfsz M,F
 goto mloop
 return
InterruptService:
 movwf w_temp      ;copy W to temp register could be in any bank
 swapf STATUS,W    ;swap status to be saved into W
 bcf   STATUS,RP0  ;change to bank 0 regardless of current bank
 movwf status_temp ;save status to bank 0 register
 bcf  PIR1,0    ;clear register overflowed
 incf Dig1,F 	;checks if Dig1 > 10
 movf Dig1,W
 addlw -d'10'
 btfss STATUS,Z
 goto exit_int
 clrf Dig1
 incf Dig2,F 	;checks if Dig2 > 6
 movf Dig2,W
 addlw -d'6'
 btfss STATUS,Z
 goto exit_int
 clrf Dig2
 incf Dig3,F 	;checks if Dig3 > 10
 movf Dig3,W
 addlw -d'10'
 btfss STATUS,Z
 goto exit_int
 clrf Dig3
 incf Dig4,F 	;checks if Dig3 > 6
 movf Dig4,W
 addlw -d'6'
 btfss STATUS,Z
 goto exit_int
 clrf Dig4
exit_int:
 swapf status_temp,W ;register into W, sets bank to original state
 movwf STATUS      ;move W into STATUS ;register
 swapf w_temp,F    ;swap W_TEMP
 swapf w_temp,W    ;swap W_TEMP into W
 retfie
	END                       ; directive 'end of program'
What could be the problem?
t.i.a.
p.s. btw, I'm posting this thread using Opera browser. I cannot neither send a private message nor post a message (or thread) using firefox 2.0 anymore.
Try changing all the call led7 instructions to movlw 0xfe and see what happens.
Mike
That is bits 6 and 7 of Port B which happens to be where the timer1 crystal would be connected to. And, I see you have enabled timer 1 oscillator.
Try changing it to,
		movlw	b'0011[COLOR="Red"]0[/COLOR]100'	;disables timer b0, internal clock b1, enable oscillator b3
Hey, it worked :D
I tested the program using Oshon PIC simulator, so I trusted on this too much
Thank you a lot Pommie :)
