PIC16F628A Rotate Left Thru Carry & Loop Around
I call peak of triangles resolution. I should be careful how I label them.
Increasing color depth is not the solution of smoothing out the color morphing as it originally appeared. I noticed when I charted all the color bits for 8 bit resolution, I was not gaining anything. I just had to deal with more zeros which means less overall brightness. The key here is to lower the color depth and increase transitions between frames with care taken to modulate fast enough not to get flickering going from one frame to the next.
Which is exactly what I did with a great success. I have lowered the triangle peaks to 3 bit brightness instead of 4 and increased number of frames from 4 to 12. To place 12 colors across 12 channels and loop them around will take 12 frames with 12 transitions with total of 12 sections (3colorsx12frames/3 duplicates). It is awesome looking! I am about to wrap up the code shortly and post. This also improved the color spread between 3 primary colors across 12 channels. Colors are more evenly spread and they are brighter. Now that I discovered how to transition from one frame to the next, I can work on transitioning from one entire entry color set to the next and also shift colors in and out like a shift register. (stand-alone device!)
I have been reverting back to 4-bit resolution for best results. I mapped the bits one more time for 4 frames, 12 sections. Then I added the bits for Red, Green and Blue individually and then graphed those points. You are not going to believe what I discovered! The 3 sets of triangles converted to 3 sine waves phase shifted by 120 degrees. Sum=Integral so it makes sense that sum of triangles is a sine wave. I am thinking Differentiation and Integration. (method1)
Setting that aside and looking at it from a Trigonometry point of view, the waves are sine waves with center point lifted by 6 points, amplitude of 6 points, and frequency of 1. Phase change each sine by 120 degrees and you have the entire graph mapped. Someone must have already discovered this I am pretty sure. But I have not seen it yet.
Why is this a big deal? Imagine you have a variable called Phi (angle) that goes from 0 to 360 degrees. While angle is changing, you take sine of it (theoratically) multiply it by 6, add 6 to it, and you have your first sine wave. Do the same with the other two sine waves and instead of using Phi, we use Phi+120, and Phi+240, do all these sine waves at the same time.
To recap we are color shifting by an angle (Circular format) and modulating it. (Circular Bit Amplitude Modulation- "CBAM") This will change everything in color mapping. I have to think about this a bit now.
As promised below is the code for ColorRot-3Bit:
  list        p=16F628A
   #include <p16F628A.inc>
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT & _LVP_OFF
    errorlevel    -302        ; supress banksel warning messages during assembly
    errorlevel    -311        ; supress HIGH operator warning messages during assembly
    errorlevel    -305
   cblock    0x20
    copyPORTA
    copyPORTB
    FrameCount
    LoopCount
    Color1
    Color2
    Color3
    Col1
    Col2
    Col3
   endc
#define        bank0    bcf        STATUS,RP0
#define        bank1    bsf        STATUS,RP0
RESET_VECTOR    org        0x000
Rainbow    macro    Col1,Col2,Col3
        movlw    Col1
        movwf    Color1
        movlw    Col2
        movwf    Color2
        movlw    Col3
        movwf    Color3
        call        MainFrames
        endm
START
    movlw    b'00000111'            ;Set all ports as outputs
    movwf    CMCON                ;Disable comparators
    bank1
    clrf    TRISA
    clrf    TRISB
    bank0
Sequence
            call        MegaColor
            goto    Sequence
MegaColor
    Rainbow    b'00010000',b'01000000',b'10000000'
    Rainbow    b'00010000',b'01010000',b'01000000'
    Rainbow    b'00010000',b'00010000',b'01010000'
    Rainbow    b'00010000',b'01000000',b'01000000'
    Rainbow    b'00010000',b'10000000',b'00010000'
    Rainbow    b'00010000',b'00010000',b'10000000'
    Rainbow    b'00010000',b'10010000',b'10000000'
    Rainbow    b'00010000',b'10010000',b'10010000'
    Rainbow    b'00010000',b'00010000',b'10010000'
    Rainbow    b'01010000',b'01010000',b'00010000'
    Rainbow    b'01010000',b'01010000',b'01000000'
    Rainbow    b'01010000',b'01010000',b'11000000'
    Rainbow    b'01010000',b'01010000',b'10000000'
    Rainbow    b'01010000',b'01010000',b'10010000'
    Rainbow    b'01010000',b'10010000',b'11000000'
    Rainbow    b'01010000',b'01000000',b'11000000'
    Rainbow    b'01010000',b'10010000',b'10010000'
    Rainbow    b'01010000',b'11010000',b'00010000'
    Rainbow    b'01010000',b'11010000',b'01000000'
    Rainbow    b'01010000',b'11010000',b'10000000'
    Rainbow    b'01000000',b'11010000',b'10000000'
    Rainbow    b'01000000',b'10000000',b'10000000'
    Rainbow    b'01000000',b'01000000',b'10000000'
    Rainbow    b'01000000',b'11000000',b'10000000'
    Rainbow    b'01000000',b'11000000',b'11000000'
    Rainbow    b'01000000',b'11010000',b'11000000'
    Rainbow    b'01000000',b'10010000',b'10010000'
    Rainbow    b'01000000',b'01000000',b'01010000'
    Rainbow    b'01000000',b'01000000',b'11000000'
    Rainbow    b'01000000',b'01000000',b'10010000'
    Rainbow    b'10000000',b'10010000',b'00010000'
    Rainbow    b'10000000',b'10010000',b'10010000'
    Rainbow    b'10000000',b'11010000',b'00010000'
    Rainbow    b'10000000',b'11000000',b'11000000'
    Rainbow    b'10000000',b'11010000',b'10010000'
    Rainbow    b'10010000',b'10010000',b'11010000'
    Rainbow    b'10010000',b'01010000',b'11010000'
    Rainbow    b'10010000',b'10010000',b'01000000'
    Rainbow    b'10010000',b'10010000',b'11000000'
    Rainbow    b'10010000',b'11010000',b'11000000'
    Rainbow    b'00010000',b'00000000',b'00000000'
    Rainbow    b'01010000',b'00000000',b'00000000'
    Rainbow    b'01000000',b'00000000',b'00000000'
    Rainbow    b'11000000',b'00000000',b'00000000'
    Rainbow    b'10000000',b'00000000',b'00000000'
    Rainbow    b'10010000',b'00000000',b'00000000'
            return
MainFrames
        movlw  d'255'
        movwf    FrameCount
FC1
        call        Frame12
        call        Frame12
        decfsz    FrameCount
        goto    FC1
        movlw  d'255'
        movwf    FrameCount
FC2
        call        Frame12
        call        Frame11
        decfsz    FrameCount
        goto    FC2
        movlw  d'255'
        movwf    FrameCount
FC3
        call        Frame11
        call        Frame11
        decfsz    FrameCount
        goto    FC3
        movlw  d'255'
        movwf    FrameCount
FC4
        call        Frame11
        call        Frame10
        decfsz    FrameCount
        goto    FC4
        movlw  d'255'
        movwf    FrameCount
FC5
        call        Frame10
        call        Frame10
        decfsz    FrameCount
        goto    FC5
        movlw  d'255'
        movwf    FrameCount
FC6
        call        Frame10
        call        Frame9
        decfsz    FrameCount
        goto    FC6
        movlw  d'255'
        movwf    FrameCount
FC7
        call        Frame9
        call        Frame9
        decfsz    FrameCount
        goto    FC7
        movlw  d'255'
        movwf    FrameCount
FC8
        call        Frame9
        call        Frame8
        decfsz    FrameCount
        goto    FC8
        movlw  d'255'
        movwf    FrameCount
FC9
        call        Frame8
        call        Frame8
        decfsz    FrameCount
        goto    FC9
        movlw  d'255'
        movwf    FrameCount
FC10
        call        Frame8
        call        Frame7
        decfsz    FrameCount
        goto    FC10
        movlw  d'255'
        movwf    FrameCount
FC11
        call        Frame7
        call        Frame7
        decfsz    FrameCount
        goto    FC11
        movlw  d'255'
        movwf    FrameCount
FC12
        call        Frame7
        call        Frame6
        decfsz    FrameCount
        goto    FC12
        movlw  d'255'
        movwf    FrameCount
FC13
        call        Frame6
        call        Frame6
        decfsz    FrameCount
        goto    FC13
        movlw  d'255'
        movwf    FrameCount
FC14
        call        Frame6
        call        Frame5
        decfsz    FrameCount
        goto    FC14
        movlw  d'255'
        movwf    FrameCount
FC15
        call        Frame5
        call        Frame5
        decfsz    FrameCount
        goto    FC15
        movlw  d'255'
        movwf    FrameCount
FC16
        call        Frame5
        call        Frame4
        decfsz    FrameCount
        goto    FC16
        movlw  d'255'
        movwf    FrameCount
FC17
        call        Frame4
        call        Frame4
        decfsz    FrameCount
        goto    FC17
        movlw  d'255'
        movwf    FrameCount
FC18
        call        Frame4
        call        Frame3
        decfsz    FrameCount
        goto    FC18
        movlw  d'255'
        movwf    FrameCount
FC19
        call        Frame3
        call        Frame3
        decfsz    FrameCount
        goto    FC19
        movlw  d'255'
        movwf    FrameCount
FC20
        call        Frame3
        call        Frame2
        decfsz    FrameCount
        goto    FC20
        movlw  d'255'
        movwf    FrameCount
FC21
        call        Frame2
        call        Frame2
        decfsz    FrameCount
        goto    FC21
        movlw  d'255'
        movwf    FrameCount
FC22
        call        Frame2
        call        Frame1
        decfsz    FrameCount
        goto    FC22
        movlw  d'255'
        movwf    FrameCount
FC23
        call        Frame1
        call        Frame1
        decfsz    FrameCount
        goto    FC23
        movlw  d'255'
        movwf    FrameCount
FC24
        call        Frame1
        call        Frame12
        decfsz    FrameCount
        goto    FC24
        return
Frame1
            call        C1
            call        Sec1
            call        C2
            call        Sec2
            call        C3
            call        Sec3
            return
Frame2
            call        C1
            call        Sec4
            call        C2
            call        Sec5
            call        C3
            call        Sec6
            return
Frame3
            call        C1
            call        Sec7
            call        C2
            call        Sec8
            call        C3
            call        Sec9
            return
Frame4
            call        C1
            call        Sec10
            call        C2
            call        Sec11
            call        C3
            call        Sec12
            return
Frame5
            call        C3
            call        Sec1
            call        C1
            call        Sec2
            call        C2
            call        Sec3
            return
Frame6
            call        C3
            call        Sec4
            call        C1
            call        Sec5
            call        C2
            call        Sec6
            return
Frame7
            call        C3
            call        Sec7
            call        C1
            call        Sec8
            call        C2
            call        Sec9
            return
Frame8
            call        C3
            call        Sec10
            call        C1
            call        Sec11
            call        C2
            call        Sec12
            return
Frame9
            call        C2
            call        Sec1
            call        C3
            call        Sec2
            call        C1
            call        Sec3
            return
Frame10
            call        C2
            call        Sec4
            call        C3
            call        Sec5
            call        C1
            call        Sec6
            return
Frame11
            call        C2
            call        Sec7
            call        C3
            call        Sec8
            call        C1
            call        Sec9
            return
Frame12
            call        C2
            call        Sec10
            call        C3
            call        Sec11
            call        C1
            call        Sec12
            return
Sec1
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            return
Sec2
            movlw    b'11111110'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'01111100'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00111000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec3
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            return
Sec4
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec5
            movlw    b'11111100'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'01110000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec6
            movlw    b'11000001'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            return
Sec7
            movlw    b'00111111'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00001110'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec8
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec9
            movlw    b'10000011'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            return
Sec10
            movlw    b'01111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00111110'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00011100'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec11
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            return
Sec12
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            return
C1            movfw    Color1
            movwf    copyPORTA
            return
C2            movfw    Color2
            movwf    copyPORTA
            return
C3            movfw    Color3
            movwf    copyPORTA
            return
Output        addwf    copyPORTA,0
            movwf    PORTA
            movfw    copyPORTB
            movwf    PORTB
            return
  end
If intention of the design is changed to color wave then hardware can easily be modified to make the firmware much simpler. Also many more RGB modules can be driven with less number of pins. Color Wave: An FX that places 12 colors across 12 channels with equal spacing and fading, then rotates colors around. In example of 12 RGB, RGB9 and RGB5 follow RGB1. So if RGB1 goes Red, RGB5 becomes Green and RGB9 becomes Blue. Similarly when RGB1 goes to Yellow, RGB5 goes to Aqua and RGB9 goes to Maganta. You will lose control of individual colors but you still have the smooth morphing between channels and colors are spread out evenly (almost perfect even). Hardware: Very similar to ColorRot with couple of major differences. R,G,B of first 4 RGB LEDs are tied together, same with RGB5-8 and RGB9-12. Then R1 is tied to G5, G1 tied to B5, and B1 is tied to R5. The wires get shifted. (R1G1B1-G5B5R5-B9R9G9)
To control 12 RGB now you need 3 pins for RGB and 4 pins for common anode for total of 7 pins used (instead of 15 pins). You can expand on this to have 12 pins common plus RGB (15 pins used) and control a whopping 36 RGB LED's. Another words a PIC16F628A can control 36 RGB led modules! With 36 RGB, the firmware is identical to ColorRot-12 but you can drive 3 times more LED's! More to come if there is an interest.
Introduction of a new program called "ColorStream". This is a 4-bit resolution color streaming. New color enters at the right side and gets morphed into existing colors and then shifted to the left (without loop around). It would have been too easy to just push the colors in one after the other. But in this code we actually incorporate the new color into the previous code by transitioning it (morphing it) into the old colors. Here is an example of what the code does: Grabs 3 initial colors, We used black, black, black. Then shift Red in. So the first step on 12 channels we have: Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Red1. Where Red1 designates the lowest brightness of Red, while Red4 depicts highest brightness. Following the shift-morph logic our next step will be: Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Blk, Red1, Red2 and so on until Red4 is reached to the far right. Then the next color is shifted in with a morph. So we have: Blk, Blk, Blk, Blk, Blk, Blk, Blk, Red1, Red2, Red3, Red4, Yellow1. We continue this entering new color, morphing, and shifting all the way to the end of our data (look up table for example).
This code will come in handy (with a bit of modification and added synchronizer) to receive 8-bit color data from an EEPROM for a continous streaming. Here is the code:
   list        p=16F628A
    errorlevel    -305
   cblock    0x20
    copyPORTA                ;Declare variables used in the program
    copyPORTB
    FrameCount
    LoopCount
    Color1
    Color2
    Color3
    Col1
    Col2
    Col3
    Speed
   endc
        movlw    Col1
        movwf    Color1
        movlw    Col2
        movwf    Color2
        movlw    Col3
        movwf    Color3
        call        MainFrames
        endm
START
    bank1
    clrf    TRISA
    clrf    TRISB
    bank0
    clrf        copyPORTA
        movlw    d'35'
        movwf    Speed
    Rainbow    b'00000000',b'00000000',b'00000000'
    Rainbow    b'00000000',b'00000000',b'00010000'
    Rainbow    b'00000000',b'00010000',b'01010000'
Sequence
    Rainbow    b'11000000',b'10000000',b'10010000'
    Rainbow    b'10010000',b'00010000',b'01010000'
        goto    Sequence
MainFrames
        movfw    Speed
        movwf    LoopCount
LC1
        call        Frame1
        decfsz    LoopCount,F
        goto    LC1
        movfw    Speed
        movwf    LoopCount
LC2
        call        Frame2
        decfsz    LoopCount,F
        goto    LC2
        movfw    Speed
        movwf    LoopCount
LC3
        call        Frame3
        decfsz    LoopCount,F
        goto    LC3
        movfw    Speed
        movwf    LoopCount
LC4
        call        Frame4
        decfsz    LoopCount,F
        goto    LC4
        movfw    Speed
        movwf    LoopCount
LC5
        call        Frame5
        decfsz    LoopCount,F
        goto    LC5
        movfw    Speed
        movwf    LoopCount
LC6
        call        Frame6
        decfsz    LoopCount,F
        goto    LC6
        movfw    Speed
        movwf    LoopCount
LC7
        call        Frame7
        decfsz    LoopCount,F
        goto    LC7
        movfw    Speed
        movwf    LoopCount
LC8
        call        Frame8
        decfsz    LoopCount,F
        goto    LC8
        return
Frame1
        movfw        Speed
        movwf        FrameCount
FC1
            call        C1
            call        Sec1
            call        C2
            call        Sec2
            call        C3
            call        Sec3
            decfsz    FrameCount,F
            goto    FC1
            return
Frame2
        movfw        Speed
        movwf        FrameCount
FC2
            call        C1
            call        Sec4
            call        C2
            call        Sec5
            call        C3
            call        Sec6
            decfsz    FrameCount,F
            goto    FC2
            return
Frame3
        movfw        Speed
        movwf        FrameCount
FC3
            call        C1
            call        Sec7
            call        C2
            call        Sec8
            call        C3
            call        Sec9
            decfsz    FrameCount,F
            goto    FC3
            return
Frame4
        movfw        Speed
        movwf        FrameCount
FC4
            call        C1
            call        Sec10
            call        C2
            call        Sec11
            call        C3
            call        Sec12
            decfsz    FrameCount,F
            goto    FC4
            return
Frame5
        movfw        Speed
        movwf        FrameCount
FC5
            call        C1
            call        Sec13
            call        C2
            call        Sec14
            call        C3
            call        Sec15
            decfsz    FrameCount,F
            goto    FC5
            return
Frame6
        movfw        Speed
        movwf        FrameCount
FC6
            call        C1
            call        Sec16
            call        C2
            call        Sec17
            call        C3
            call        Sec18
            decfsz    FrameCount,F
            goto    FC6
            return
Frame7
        movfw        Speed
        movwf        FrameCount
FC7
            call        C1
            call        Sec19
            call        C2
            call        Sec20
            call        C3
            call        Sec21
            decfsz    FrameCount,F
            goto    FC7
            return
Frame8
        movfw        Speed
        movwf        FrameCount
FC8
            call        C1
            call        Sec22
            call        C2
            call        Sec23
            call        C3
            call        Sec24
            decfsz    FrameCount,F
            goto    FC8
            return
Sec1
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            return
Sec2
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'01111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec3
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec4
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            return
Sec5
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'01111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec6
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec7
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            return
Sec8
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'01111110'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec9
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec10
            movlw    b'10000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            return
Sec11
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            movlw    b'11111110'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            movlw    b'11111100'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec12
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec13
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            return
Sec14
            movlw    b'11111111'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11111110'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            movlw    b'11111100'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00000001'
            call        Output
            return
Sec15
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000001'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec16
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001110'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec17
            movlw    b'11111110'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11111100'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00000011'
            call        Output
            return
Sec18
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000011'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec19
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001100'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec20
            movlw    b'11111100'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00000111'
            call        Output
            return
Sec21
            movlw    b'00111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec22
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00001000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00000000'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
Sec23
            movlw    b'11111000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11110000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11100000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            movlw    b'11000000'
            movwf    copyPORTB
            movlw    b'00001111'
            call        Output
            return
Sec24
            movlw    b'01111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00111111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00011111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            movlw    b'00001111'
            movwf    copyPORTB
            movlw    b'00000000'
            call        Output
            return
C1            movfw    Color1
            movwf    copyPORTA
            return
C2            movfw    Color2
            movwf    copyPORTA
            return
C3            movfw    Color3
            movwf    copyPORTA
            return
            movwf    PORTA
            movfw    copyPORTB
            movwf    PORTB
            return
  end
So far we have created a family of FX for 12 channel RGB:
ColorMorph: All 12 channels together shift color from Red thru colors of rainbow back to Red.
Fix3Color: Produced 12 fix colors across 12 RGB with morphing in between (static colors with no movement)
ColorRot: 12 Colors are produced on 12 channels with morph in between and then rotated with a loop around
ColorStream: 12 colors are produced on 12 channels with morph in between, new color is entered to the right, morphed in, and then shifted to the left. Last color drops off with no loop around.
Since the topic of original post started with rotate bits. I will go back to the original concept of generation of 12 colors across 12 channels and rotating them (ColorRot).
Given:
User enters 3 primary colors (Choose: R, RG, G, GB, B, BR, W, BLK)
Color Resolution:3 bits
Required data lines to create one frame: 9 lines (9 lines of 12-bit long)
It takes 4 frames to go from primary color1 to primary color2
It takes 3 colorsets across 4 frames to complete one complete rotation of colors across 12 channels. i.e.: Once 4 frames are completed primary color 1 and 2 switch places and so on. Hence only 4 frames are needed, then rotate primary colors and do 4 frames again. Rotate primary colors one last time and repeat 4 frames. (example: when LED1=Red, LED5=Green, LED9=Blue, do 4 frames to shift LED1 from Red to Green and that shifts LED5-12 automatically). You will need 4 more frames for LED1 to go from Green to Blue, and another 4 frames to go from Blue to Red. That is 3 times doing 4 frames with primary colors rotated.
Implementations:
Create 9 lines:
L1: 1110-0000-1111 (to be placed in A3-A0 and B7-B0)
L2: 1100-0000-0111
L3: 1000-0000-0011
L4: 0000-1111-1110
L5: 0000-0111-1100
L6: 0000-0011-1000
L7: 1111-1110-0000
L8: 0111-1100-0000
L9: 0011-1000-0000
Create 3 Colorsets:
Read user given 3 primary colors and place them in Color1,Color2,Color3
Colorset1: C1,C2,C3 (place Color1 in C1, Color2 in C2, Color3 in C3)
Colorset2: C2,C3,C1 (Place Color1 in C2, Color2 in C3, Color3 in C1)
Colorset3: C3,C1,C2 (place Color1 in C3, Color2 in C1, Color3 in C2)
Create 4 Frames:
Frame1
Place C1 in A7-A4
Put L1 in A3-A0 and B7-B0 -> Output
Put L2 -> Output
Put L3 -> Output
Place C2 in A7-A4
Put L4 -> Output
Put L5 -> Output
Put L6 -> Output
Place C3 in A7-A4
Put L7 -> Output
Put L8 -> Output
Put L9 -> Output
Frame2
Place C1 in A7-A4
Rotate L1 -> Output
Rotate L2 -> Output
Rotate L3 -> Output
Place C2 in A7-A4
Rotate L4 -> Output
Rotate L5 -> Output
Rotate L6 -> Output
Place C3 in A7-A4
Rotate L7 -> Output
Rotate L8 -> Output
Rotate L9 -> Output
Frame 3 and 4 are similar to Frame 2 with lines rotated
Program:
Call Colorset1: C1, C2, C3
Call Frame1
Call Frame2
Call Frame3
Call Frame4
Call Colorset2: C2, C3, C1
Call Frame1
Call Frame2
Call Frame3
Call Frame4
Call Colorset3: C3, C1, C2
Call Frame1
Call Frame2
Call Frame3
Call Frame4
End
Challenges I have had so far: During the time I shift bits and rotate primary colors the color rotation gets paused. (stop and go) I have to find a way to rotate bits faster and time the frame to frame transitions such that it takes equal amount of time as rotations. I could use some suggestions....
To get a stable time base, you need a timer interrupt. Set your LEDs first thing after the interrupt is called. If you want to switch at 60Hz x 3 channels x 32 (5 bit) resolution = about 6kHz - one interrupt every 170 us - not very challenging speed. Then you can run any stuff between iterrupts without distubing the time base.
Thanks North. I will work on that when I have some time.
Here is the code for ColorRotate modified, cleaned up and commented.
Thanks to all for great feedbacks. Special thanks to Mike-K8LH for his contributions.
  • A12 Color Rotate 4-Bit Res.pdf
Working on 18 RGB version now. 9 shared data bits, 2 sets of RGB. Hardware design is completed, will work on the code time permitting.
I tried to create a 12-bit variable and rotate it. But during assembly processor gave me an error message indicating that the string was too long and it chopped it down to the least significant 8 bits. Is there a trick to creating a 12-bit variable (may be in declaration) or PIC16F628A can not handle a "word" variable?
Regards,
Rom
Follow up post: I do not believe it is possible with PIC16F628A to generate 16-bit (or 12-bit) variables and cobnstantly rotate them. I kow W-register can hold a "Word" (16-bit number) and do something with it. But I have not find any examples that show these values can be passed on to a 16-bit variable. Until additional discoveries, I broke up each data-line into two 8-bit variables and named them High and Low. See next post for details.
Here is the code for A12-ColorRotate with Rotate Left Function. It is not the most efficient way to implement color rotate, nor the color transitions are as smooth as one would like. Nevertheless, the code works beautifully.
Concept: Firmware generates 12 data lines which hold the color triangles. Then these data lines are rotated and appropriate color-bits are added at the right time and displayed.
Implementation: User provides 3 colors. Code grabs these 3 colors and place them in Color1, COlor2, Color3 each a 4-bit number (with upper 4-MSB used). Every 4 data lines gets one color to cover all 3 colors over 12 lines. Then these data lines are rotated and colors added once again and display. As before each frame contains the data lines for 12 RGB LEDs multiplex RGB. 12 Frames (12 rotatations) will cover rotation of colors from RGB1 thru RGB12. Then next set of colors are selected from user provided table.
  • A12-ColorRot-RotL3.pdf
Here is one more method of Rotate Left Bits for ColorRotate. This time brightness is implemented on RGB and not on data lines (A3-A0 & B7-B0). To get 12 desired colors across 12 RGB, we simply mix different ratio of each primary color. Red=4 times red, Orange=3 times red, 1 time green, and so on.
As before user provides 3 colors. Colors are placed in 3 variables. We Initialize data line (0000-0000, 0000-0001) corresponding to (LHigh, LLow).
We cross fire B0 with color1, rotate data line (now 0000-0000 0000-0010), implement color2. Every 4 rotations we rotate the colors from color1 to color2, color2 to color3, color3 to color1 to capture 12 colors. (3 sets of 4 rotations, 4 colors) The final trick is once you complete a frame to rotate the bits one extra time. This allows color1 to fall on 0000-0000, 0000-0010 (instead of 0000-0000, 0000-0001) and then rotation continues. So from one frame to the next the entire data line mapping is turn left one, creating the color motion. This code is a lot simpler and more efficient. Colors are much brighter and fading is smoother.
  • A12-ColorRot-RotL5.pdf
Quick tip (trick) to increase color saturation of one color over the other (color correction) when morphing: Let's say you have implemented your color mapping and you noticed on your RGB LEDs color red is weaker than green and blue. Hence your color wheel is shifted more towards green and blue. i.e.: Yellow is more greenish, and magenta is more purplish.
To correct this, change the order of color bits to be pushed out last. For example above when doing 1 red, 3 green. set your greens first then red at the end. For color yellow, do two greens first, then 2 reds. You can make this correction going from red to green, greeen to blue, and blue to red transitions. It makes a noticable difference!
Another tip when color matching your RGB LED's: Before soldering your LED's, build a quick jig on a protype board and test your LED's 2 by 2 to find out the best resistor values. Focus on colors: Yellow first (equal red & green), then on Magenta (equal red and blue) and finally white (red + green +blue). You might have to do several adjustment going thru these colors sets. Once you have the perfect combination then write down what values of resistors you calculated and build your circuit. You will find out that RGB LED's have different color rendering from one to another even within the same "bin". To do your fine tuning of the final colors use trick one by rearranging color bits in your firmware. Happy Coloring.
To wrap up this post I started this project with a color graph of the desired output of LED's. Then proceeded putting together the concept of general code. Once that was done, I broke down the project in hardware and software in steps and implemented subroutines and macros to shorten the code and put everything together. Here are a few challenges I went thru and learned by experimenting, calculating, and experimenting again:
1- The challenge in multi RGB color decoding is that we are trying to force a 3D effect into a 2D programing then display it back in 3D. We have color choice (RGB), Brightness, and Port Pins as our dimensions. I found out the most efficient way to do this is to scan all Reds, Greens and Blues in 3 passes. Combine brightness with data bits as your first dimension and your second dimension is your color sets. The codes are written for an array of input colors. One can simplify the codes if only a sinple RGB is used.
2- The challenge for circuit design and calculating available current for each RGB: The best tackle is first calculate how much current your microcontroller can put out since we are direct driving (for PIC16F628A max combined two ports output current is 200mA). Then figure out how much current your NPN transistors need to fully turn on (Base current x current gain = Max Emitter current sinking ability). Most standard transistors require turn-on base voltage of 2V with approximate base current of 5mA (with conservative gain of 50). Now 200mA minus (3x5mA=15mA) for transistors and you have 185mA available current to source the anodes of 12 RGB (approx. 15mA per RGB). But remember we are scanning R, G, then B. So at each given time we have 15mA available for each individual color (R,G,B) on all 12 RGB LEDs! (15x12=180mA, with 5mA to spare)
3- Now we know how much current is available to each RGB. One method of supplying currents to each RGB is to have individual resistors for each color on each LED before you tie them together. To cut down on parts and to simplify the PCB layout, I elected to do this differently. I used two resistors instead of 3 and I placed them stratigically on Anode and Red. This makes the calculations a bit more challenging since you have different Vf and If for colors. To make the matters worse to balance the colors you will need to compensate for brightness of R,G,B to give you a great color mix. On most RGB+ : Common Anode with frusted lens (better than clear lens) you will discover that red is the weakest color. So where do we start?!
I had to solve two equations (one for red and one for GB). Let's tackle Red first. We know at full brightness Red uses 20mA at 1.9V. But we only have 15mA available. We do a quick approximation: 1.9x15/20=1.43V,......So at 15mA Red will have a voltage of 1.43V across it. Hold this number.
For G & B typically, at 20mA we have Vf of 3.3V, but we only have 15mA. Again with approximation we calculate that at 15mA, we have 2.5V across G & B. To compensate for color mixing, you will find out that you need to run G & B at 90% of that voltage (& current) corresponding to 2.3V across G & B at current of 13.8mA. The anode resistor then will have 2.7V across it with 15mA thru it. So Resist for anode is 180 ohms. Now the juction of anodes of RGB have a voltage of 2.3 and Red uses 1.43V at 15mA. So series Resist for Red will have the value of (2.3-1.43)/15mA=58 ohms (you can use 56 ohms standard or use 51 since we have some playroom in our overhead current). Again as a reminder each manufacturer has specific color rendering and brightness. Not to mention color may vary from batch to batch during manufacturing. In conclusiong you might have to adjust the resistor values once again to get your desired mix and color balance. As a tip if you think you need to reduce the brightness of GB by increasing Anode resistor by 10 ohms, only increase it by 5 ohms and reduce Red series resistor by 5 ohms. The entire circuit uses 200mA at 5v for total of 1W. If you leave this circuit on 24 hours, 365 days, your annual electric usage is about $12 ($1/month). I recommend experimenting with the codes in this post as it will provide you with an insight of color coding. Your challenge is to simplify the codes and make them more efficient. Cheers.
Additional Developement Regarding Color Mixing and RGB Balancing:
While one can alway do color balancing thru firmware or trial and error with hardware, I was able to create a way to balance RGB via formulas and an Excell sheet which anyone can put together with a bit of study. This process involved looking at individual chromographic characteristic of each color LED (x,y,z), view angel, individual lumen-intensities, and quantity of each color used in a module to obtain a pure white color. These variables along with individual LED Vf and If were entered into the spreadsheet. By adjusting number of each color used, spreadsheet calculates total X,Y,Z along with total MCD, Lumens, Currents thru each group of color (say 5 red, 3 green, 3 blue), required series resistor, total current and total wattage for individual module. Once all colors are balanced X,Y,Z become precisely (or very close to) 0.333, 0333, 0.334 which is pure white. This step will save tremendous amount of time in prototyping, increases overall efficiency of each module and provide the user with an excellent color mixing. This also allows user to use different type of LED's for different RGB module configurations. (Example 5mm 20 degree spots, 5mm 120 degree Strawhat flood, or 5050 RGB strips)
