PIC16F628 code error
kalingajay
Hi all,
I have few numbers of PIC16F628 (not 16F628A) microcontrollers. I wrote a .asm code to test PICs like below.
LIST P=16F628
#include <P16F628.INC>
__CONFIG _PWRTE_ON & _WDT_OFF & _ER_OSC_NOCLKOUT & _BODEN_OFF & _LVP_OFF & _CP_OFF & _MCLRE_OFF
errorlevel -302
org 0x00
goto init
org 0x04
init
clrf PORTA
clrf PORTB
movlw 0x07 ; Turn comparators OFF and enable pins for I/O
movwf CMCON
bcf STATUS,RP1
bsf STATUS,RP0 ;switch to bank 1
clrf TRISA
clrf TRISB
bcf STATUS,RP0 ;switch back to bank 0
START MOVLW B'00000001' ;
MOVWF PORTB
CALL DELAY
MOVLW B'00000010' ;
MOVWF PORTB
CALL DELAY
MOVLW B'00000100' ;
MOVWF PORTB
CALL DELAY
MOVLW B'00001000' ;
MOVWF PORTB
CALL DELAY
MOVLW B'00010000' ;
MOVWF PORTB
CALL DELAY
MOVLW B'00100000' ;
MOVWF PORTB
CALL DELAY
MOVLW B'01000000' ;
MOVWF PORTB
CALL DELAY
MOVLW B'10000000' ;
MOVWF PORTB
CALL DELAY
GOTO START
DELAY MOVLW .75
MOVWF 2CH
STK DECFSZ 2AH,1
GOTO STK
DECFSZ 2CH,1
GOTO STK
RETURN
END
The code can compile and program PIC without any error. But with practical circuit any LED not light up. Please anyone can tell me what is the error of this code?
It is probably your config, you have it set to use an external resistor, try setting it to use the internal oscillator.
Thank you for your reply. But I tried both ways. Last time I used a PCB with external RC oscillator. I send you schematic.
Kalinga.
Jon said:
I posted it to Paste Bin since the code tags on ETO no longer maintain the proper spacing between columns in asm code.
Are you sure!! If you do it manually it seems to be okay
   list     p=16F628, r=dec, w=-302
   __config   _LVP_OFF & _BOREN_OFF & _PWRTE_ON & _WDT_OFF & _FOSC_INTOSCIO
   cblock   0x70
     COUNT1
     COUNT2
     COUNT3
   endc
   org   0x00
   goto   init
   org   0x0100
init
   clrf   PORTA     ;clear PORTA output latch
   clrf   PORTB     ;clear PORTB output latch
   movlw   0x07     ;Turn comparators OFF and enable pins for I/O
   movwf   CMCON
   banksel   TRISA     ;bank 1
   clrf   TRISA
   clrf   TRISB
   banksel   PORTA      ;bank 0
   bsf   STATUS,C   ;set carry bit
   rlf   PORTB,F     ;shift left
   movlw   4      ;786mS delay
   call   DelayVar
   goto   $-3     ;loop forever
DelayMain
   movlw   256
   movwf   COUNT1
   movwf   COUNT2
   decfsz   COUNT1,F
   goto   $-1
   decfsz   COUNT2,F
   goto   $-3
   return
DelayVar
   movwf   COUNT3
   call   DELAY
   decfsz   COUNT3,F
   goto   $-2
   return
   end
Oh!! You mean the second column... I see!!
The ER oscillator only uses a resistor and not a capacitor, however, 5pf is not going to make much difference. What I did notice was the lack of capacitors on the 7805. I can't see any reason the above code won't work so check your circuit carefully.
JON, rlf will leave the code open to RMW errors if any pin is heavily loaded (LED without resistor etc.). Also, relying on the Carry bit not getting corrupted is not a good idea, especially when the OP tries modifying the code which he no doubt will. Not criticizing, just pointing it out for any future readers.
Try a '628a version.
I've had all kinds of compatibility issues with the '628, you programmer may not be programming correctly, does the device verify?
I doubt you wold get RMW errors with a basic resistor / LED circuit... I thought it was more on the slow changing circuits, capacitance and the like....
If you had quoted a bit more it would have said "LED without resistor" as I was warning any future readers about the possible problem, in fact I said that as well.
That is something that is unlike the 8051. With the 8051 and RMW instructions, it is the port latch that is read, then modified, then re-written. I wasn't aware that the PIC reads the pin instead of the latch. My apologies.
That being said, there should NEVER be a time where the pins are driving LED's without resistors. Even when multiplexing a 7-segment display, I've always used at least 100R resistors on the cathode drive port. Then I use a 2nd port for driving the anode transistors with an RLF instruction for shifting the "digit on" bits. But these pins are not loaded hardly at all since they're just base driving the transistors with a decent value base resistor on the pin.
My style of embedded circuit design is the design the circuit such that the uC's job is just to generate the required control signals but is buffered from the load itself. Probably a reason why I've never run into this issue.
