PIC program Error message. Can someone help?
BABYBASS210
Hello everyone,
I am trying to program a 16F84 and I am having some difficulties.
What I want to do is change the state of outputs portA and port B at the same time but I get errors when I assemble.
Can someone take a look and please help me out?
Thank you so much.
Sincerely,
Joey Hernandez.
Here is the program:
; CONFIGURATION FUSE
__CONFIG 0x3FFB
STATUS equ 0x03
RP0 equ 0x05
PORTA equ 0x05
PORTB equ 0x06
TRISA equ 0x85
TRISB equ 0x86
DelayA equ 0x0C
DelayB equ 0x0D
DelayC equ 0x0E
; START
org 0h ; startup address = 0000
movlw b'00000000'
movwf PORTA ; all PORTA pins = 1
movlw b'11111111'
movwf PORTB ; all PORTB pins = 0
bsf STATUS,RP0 ; set RP0 for RAM page 1
movlw b'00000000' ; all PortA = outputs
movwf TRISA
movlw b'11111111' ; all PortB = outputs
movwf TRISB
bcf STATUS,RP0 ; set RP0 for RAM page 0
MainLoop movlw b'00000001'
movwf PORTA
call Delay500
movlw b'11111110'
movwf PORTB
call Delay500
movlw b'00000010'
movwf PORTA
call Delay500
movlw b'10111101'
movwf PORTB
call Delay500
goto MainLoop ; do this loop forever
end
; SUBROUTINE: waste time for 500mS
Delay500 clrf DelayA ; clear DelayA to 0
clrf DelayB ; clear DelayB to 0
movlw 3h ; set DelayC to 3
movwf DelayC
Wait1 decfsz DelayA ; subtract 1 from DelayA
goto Wait1 ; if not 0, goto Wait1
decfsz DelayB ; subtract 1 from DelayB
decfsz DelayC ; subtract 1 from DelayC
return ; finished the delay
end
THESE ARE THE ERROR MESSAGES:
Message[302] C:\3081\GFD.TXT 34 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\3081\GFD.TXT 36 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\3081\GFD.TXT 41 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 45 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 49 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 53 : Symbol not previously defined (Delay500)
BABYBASS210
Correction on the spacing of the program.
Even though the program looks wrong because of the spacings, the spacings where correct the got repositioned when I copied and pasted it to the Electro Tech message body.
Joey Hernandez
motion
Be careful where you place the END statement. All statements are ignored after that.
