Pic problem
You need the LF version to work on 3V and even then it may require a higher voltage when using a higher clock frequency.
Check the data sheet for the PIC chip that you are using, it shows graphs and tables of it's power requirements.
That depends on frequency. Most non-LF PICs are specified to run at 2 volts at the frequencies achievable by their internal oscillators.
Mike
Also, check you don't have Brown Out Reset turned on in the config.
