PIC motor control coding problem
shredder001
Hello! This is my first post. I am currently planning to be able to control a motor from a PWM input. Since I am very new to C programing, I am going in steps at a time and using LED's to test. Here is what I have so far:
#include <pic.h>
__CONFIG(FCMDIS & IESODIS & INTIO & MCLRDIS & WDTDIS & UNPROTECT);
//Initialize
unsigned char TIMER_COUNT_LOW; // Holding register for TMR0 low byte
unsigned char TIMER_COUNT_HIGH; // Holding register for TMR0 high byte
main()
OSCCON = 0b00000001; // Internal oscillator for system clock
PORTC = 0x00;
CMCON0 = 0b00000111;
ANSEL = 0x00;
TRISC = 0b00111100;
PR2 = 0b11111111; //Set the PWM period by loading the PR2 register
CCPR1L = 0x00;
T2CON = 0b01011000;
TMR2IF = 0; //clear bit for timer2 module interupt flag
while(TMR2IF == 0) //Wait until timer2 overflows then continue
TRISC = 0x00;
ECCPASE = 1; // for future part of program
PORTA = 0x00;
CMCON0 = 0b00000111; // comperators off
ANSEL = 0x00; //digital
TRISA = 0b00101000;
T1CON = 0b00010101;
while(1==1) // Start MainLoop
while(RA5 == 1) //Wait until RA5 goes low then continue
while(RA5 == 0) //Wait until RA5 goes high then continue
TMR1H = 0x00;
TMR1L = 0x00;
while(RA5 == 1) //Wait until RA5 goes low again
PORTC = TMR1L;
It starts timer1, then waits untill a low signal on RA5 (PWM input), then a high one, then it initializes timer1 and wait for a low signal. imediatly after that, it puts the timer1 value into a variable and the displays it on PORTC (LED array). I compiled and programmed it succesfully, but it does not seem to be displaying the value, any thoughts? Thanks!!
shredder001
Sorry forgot to mention that :D I am using a pic16f684. Birdman, does it really matter if I use the whole portc as output?
be80be
Theirs only 6 pins on portC of a 16f684 you only have 2 set as output
Firstly, you set PORTC as mostly output "TRISC = 0b00111100;"
So they wouldn't all be able to be outputs.
I think he been around me LOL he was saying you only have 2 pins as output on portc
should be this portc = 0b00000000;"
birdman0_o
Active Member
Your code looks like giberrish, there are a lot of loops that do nothing, could you explain it please?
It would help if you turned on the Timer2
T2CON = 0b01011100;
shredder001
Well, I am controling the speed and direction of the motor using a PWM input on RA3. Since I am doing it in sections, I havent made the rest of it yet. The first while loop;
while(RA5 == 1), waits until the signal on RA3 goes low then continues to the second; while(RA5 == 0), which waits until the signal on RA3 goes high then continues to reset the timer1 low and high byte registers. When the signal goes high again (third while), It throws the value of TMR1L into portc to be displayed, and then repeats.
be80be
try this and see what happens
main()
    PORTC = 0;
    CMCON0 = 7;                 //  Turn off Comparators
    ANSEL = 1 << 3;             //  RA4 (AN3) is the ADC Input
    ADCON0 = 0b00001101;        //  Turn on the ADC
                                //   Bit 7 - Left Justified Sample
                                //   Bit 6 - Use VDD
                                //   Bit 4:2 - RA4
                                //   Bit 1 - Do not Start
                                //   Bit 0 - Turn on ADC
    ADCON1 = 0b00010000;        //  Select the Clock as Fosc/8
    TMR2 = 0;                   //  TMR2 Provides PWM Period
    PR2 = 64;                   //  15 kHz PWM Frequency
    T2CON = 0b00000100;         //  Enable TMR2
    CCPR1L = 0;                 //  0 Duty Cycle to Start Off
    while(1 == 1)
        NOP();
        for (Dlay = 0; Dlay < 6666; Dlay++);  //  100 ms between Samples
        NOP();
        GODONE = 1;             //  Read Pot Value
        while (GODONE);
        ADCValue = ADRESH;      //  Read in ADC Value
        if (ADCValue > 0x80)    //  go Forwards
            CCPR1L = (ADCValue - 80) >> 1;
            CCP1CON = 0b01001110;
            TRISC = 0b011011;   //  RC5/RC2 Output, RC3/RC4 Input
        else                    //  Go in Reverse
            CCPR1L = (ADCValue  ^ 0x7F) >> 1;
            CCP1CON = 0b11001110;
            TRISC = 0b100111;   //  RC5/RC2 Output, RC3/RC4 Input
        }  //  fi
    }  //  elihw
}  //  End cMotor
it reads a pot and sets the speed by it
shredder001
Thanks guys, I got it working (turns out I forgot to turn TMR2 on). If I need any help on the next part, Ill be sure to ask. Thanks!!
