PIC 12F629 programming help
koyaelektronic
Hello,
I am new to this forum,have been following it for some time now,and I decided to join.
I am looking to program a PIC 12F629 to do a very simple function,but I don't know the coding.
Here is what I need:
3 INPUTS
1 OUTPUT
IF INPUT 1 gets a positive impulse on it,and INPUT 2 gets a positive impulse on it,then OUTPUT releases positive impulse lasting 2 seconds.
IF INPUT 1 gets a positive impulse on it,and INPUT 3 gets a positive impulse on it,then OUTPUT releases 2x positive impulse lasting 1 second each.
My problem is I am not into coding at all.Now if someone could help me with writing a code for my project,it would be awesome,because I would like to start learning how to program PIC circuits.
With kind regards,
Sima
Here's some untested code that you could start with. You need to add the delayms macro and include the correct header.
out1		equ		0
in1			equ		1
in2			equ		2
in3			equ		3
state		equ		0x10
setup:
	bsf 	STATUS, RP0 	; Bank 1
	call 	3FFh 			; Get the cal value
	movwf 	OSCCAL 			; Calibrate
	movlw	0xFE			; GP0 is the output; all others are input
	movwf      TRISIO
	bcf 	STATUS, RP0 	; Bank 0
	movlw	0xFF
	movwf	state
loop1:
	movfw	GPIO
	andlw	(1<<in1)|(1<<in2)
	xorlw	(1<<in1)|(1<<in2)
	btfsc	STATUS,Z
	goto	doSinglePulse
	bcf		state,0
loop2:
	movfw	GPIO
	andlw	(1<<in1)|(1<<in3)
	xorlw	(1<<in1)|(1<<in3)
	btfsc	STATUS,Z
	goto	doDoublePulse
	bcf		state,1
	goto	loop1
doSinglePulse:
	btfsc	state,0
	goto	loop1
	bsf		state,0
	bsf		GPIO,out1
	delayms 2000
	bcf		GPIO,out1
	goto 	loop1
doDoublePulse:
	btfsc	state,1
	goto	loop2
	bsf		state,1
	bsf		GPIO,out1
	delayms 1000
	bcf		GPIO,out1
	delayms 500
	bsf		GPIO,out1
	delayms 1000
	bcf		GPIO,out1
	goto 	loop2
If you prefer C here's some code you can put in your main() function loop;
  // code to make 0,1,2 pulses based on inputs
  if(IN1)
    if(IN3) make_pulse;
    if(IN2 || IN3) make_pulse;
Hey guys,thank you for the info...As I said I am a complete n00b when it comes to PIC programming?
So:
1)What is delay ms macro,and how to create it?
2)What would be the correct header?
3)What compiler to use for programming this?
I have made PICKit 2 clone,and this is where my knowledge stops.
Kind regards,
Sima
If you are going down the ASM route..
1) Depends on the crystal you are going to use... Ie.. a 20Mhz crystal's clock cycle is 200nS so you'll need to count 5000 clocks to make 1 millisecond..
2) include "p12f629.inc"
3) Compilers are for C, basic and pascal... You'll be using MPASM... comes bundled with MPLAB IDE.
The pickit clone should work fine with MPLAB IDE.
Yes!! A 4Mhz crystal gives a 1uS clock cycle.... so 1000 clocks equal a millisecond...
There are many examples of this type of delay... I recomend you look at Nigel's tutorials link in my signature.. they will help you to get started...
PIC MPLAB screen
Hey Ian,
here is my progress so far,I have switched to PIC12F675,since there is no 629 in my store.
I have found the correct header,and inserted i correctly(hopefully).
The new clock is 20MHz.
WKR,
Sima
Hi Sima,
Now, add your source file. You may want to put it in its own folder, because MPLab will add some files to it when you build (compile) the project. That is a personal preference and is certainly not any requirement.
John
Main.asm
Hey jpanhalt,
I have copied what dougy83 wrote earlier in the thread,and named it main.asm,and I had put in source files,so my project now looks like this.I think you meant for me to do that,right?
Kind regards,
Sima
The pic12f675 has a 4Mhz internal crystal aswell!!
Just put it all in a single file
	list	p=p12f675
	#include <P12F675.inc>
	__CONFIG(0x31DD)
	errorlevel -302; gets rid of bank select error
; variables
var1	equ 	20h			; declare a byte
cnt		equ		21h
cnt1	equ		22h
cnt2	equ		23h
; vectors
		org 	0
		goto	init		; vectors go here
; initialisation
init
		banksel	TRISIO
		movlw	0
		movwf	TRISIO
		banksel	GPIO
		movlw	0
		movwf	var1
; main loop
loop
		movf	var1,w
		incf	var1
		movf	var1,w
		movwf	GPIO
		andlw	.8
		btfss	STATUS,Z
		clrf	var1
		call	delayMs
		goto 	loop
delayMs	movlw	.248
		movwf	cnt
		nop					;  5 instructions
		nop					;  +
		nop					;  the loop.
dly		nop					; (4 x 248uS = 992)
		decfsz	cnt,f		;  =
		goto	dly			;  997
		return				;  + three for the call = 1000uS
		end
simple program with a 1mS delay and variables and config settings for internal OSC..
Sorry for bothering you guys,I just don't get,and I am dropping this.
Admins please delete/close this thread.
Thanks for all who tried to explain
Bye bye
Don't give up after 3 days.
Choose an 18F series PIC and try Swordfish BASIC (easy) or learn XC8 using MPLABX (moderate).
A good beginners book might also help, Myke Predko published some very good ones.
