photodetector
aspoojak
hey, i ve been working on the photodetection property of LDR.
i need to know which one of the 3 photodetectors s better for the detection of red light. right now i'm using an LDR. i need to convert the output to frequency. how do i do it?? or is it better tht i use a phototransistor and use v-f converter.
Break it down to three questions:
What detector is sensitive to red light?
How do I make a circuit so the detector makes a voltage proportional to illumination?
How do I convert voltage to frequency?
CdS cells (photoresistors) have a peak sensitivity at the green wavelength, but are quite useable to detect red light.
Silicon photodectors (photdiodes or transistors) have a peak sensitivity at the infrared wavelengths, but are alse quite useable at red.
So your first order of businnes is to get a good optical red filter to place in front of your detector.
Now, if you want to go the easy route, Avago Techonologies has a broad range of light sensors with the output properly conditioned:
Avago's Ambient Light Sensors
hey fernando_g
i understand the importance of optical filters.i need help on selecting the detector. or is it better if i use a light to freq converter?
I found something better, it already has the RGB filters built in, and also provides an output frequency.
See the AXE045 color sensor
