parallel in series
Big Sammy
Hey all...I need to wire 10 red led's (1.9V@20ma) from a 9 v battery. I was going to make them sequentially flash, but the flahsing circuit wouldn't cooperate no matter how many times I re-wired it.....I just want them to go on, and am struggling as to how to calculate the resistance needed, and the best way to do it.....2 parallel sets of 5 led's wired in series? If that is the best way to wire it, am I correct in figuring I need 52 ohm resistors on each led? (I realize I will have to get 56 ohm). Thanks for any info. on this one....
5 x 1.9V = 9.5V so I don't see how you expect to light 5 LEDs in series with a 9V battery. :confused:
You can two sets of four in series for 7.6V with a (9-7.6) / 20mA = 70 ohms in series with each set, and one set of two in series for 3.8V with (9-3.9) / 20mA = 255 ohms in series.
Since the current draw would be the same (60mA total) you could just use three strings of 4 in series with a 70 ohm resistor in each string for a total of 12 LEDs.
And apart from Carl's comments about lack of voltage .....
lets see your circuit you your were trying to use to do the sequential flashing :)
Dave
I was thinking of putting 5 led's in parallel (9-1.9/.1)....(this would be the 20ma*5)....two of these parellel circuits wired together in series....but I'm not sure if I would have to do the following: [9-1.9-1.9(voltage drop for both parallel circuits wired in series)/.1]?
You shouldn't put the LEDs in parallel.
If you put two in series, that's 3.8 V. That leaves 9 - 3.8 V = 5.2 V. For 20 mA you want 5.2 / 0.02 = 260 Ω (You can use 270 Ω as that is a standard value)
Then just make that same circuit with 2 LEDs and a 270 Ω resistor, four more times.
That way, if there is any variation in between the LED voltages, it will not affect the current in any LED significantly.
If you put 5 LEDs in parallel, and one of them happens to have a lower voltage, it will take more current than the others.
LEDs are not voltage devices they are current devices. You should never place 3.3 volts across a "3.3 volt" LED. It is a 350mA LED that just happens to need approximately 3.3 volts to work.
There is no point discussing resistor values unless the output resistance of the flasher circuit is shown.
