Paralel data trasfer between pics//memory
TKS
i was wondering,
if you just hook up 2 pics whit lets say 6 pins.
and 4 of them you would use for data transfer??
the other 2 pins are control lines..
would i be possible to trafer a number for example 35 to the other pic??/
TKS
wich memory is generally used instead of a i2c eeprom and is faster???
i need to write and read very fast..(faster as 1ms)
TKS said:
i was wondering,
You could, but it's far easier to do it via just one pin and use a serial transfer method, if you have PIC's with hardware USART's it's even easier. But even with a software UART it's still plenty fast enough for most purposes.
It depends on what you are trying to do?, you can always simply connect a static RAM to a PIC, using the PIC pins to provide the address and data lines.
Re: ...
TKS said:
Can you give me a type of ram that is commonly used and has lets say
8Kb space??/
In the past the 6116 was popular, but it's only 2KB, I've got a larger one at home used in an EPE project, I'll look what the number on it is!.
mem
ok, the brand new//data sheet link would be very nice..
its for a excel sheet something...
i need speeds thats the only way to go..:D
TKS
Go to digikey.com and do a search on SRAM. You can use their great search utility to find the right ram chip. Parrallel ram is the fatest but SPI(or 3 wire) ram should be fast enough for a 1ms read and write even i2c ram should be fast enough.
Nigel,
i found a nice chip on my big client TI :wink: :lol: :lol:
But where can i learn some more about the intern sturcture of memories.
Example: 8Kx8 means???
and i now that when i read out the pins (8 because of 8bit???)
i in fact do 2^1 2^2 2^3 2^4 2^5 etc.. and i make up that way the value right??
hope you can give me a page or good book about that stuff
TKS
TKS said:
Nigel,
TKS
8kX8 is a 64K chip organized as 8 bits wide X 8k long
some are just 4 bits wide ---while others are 32 bits wide..
Re: ...
samcheetah said:
Nigel Goodwin said:
8Kb space??/
which project
It was a simple PIC oscilloscope, it uses a 16F877 to sample into the ram, then transfers to the PC via the parallel port.
which issue was it. of all the issues i have i could only find one oscilloscope project which came in the October 2000 issue. it also used the 16F877 but it used the TC55257DPL-85L 32K Byte SRAM.
I'd have to look back for the magazine, I read the chip number off the actual chip - I didn't use the same chip as the original design, it had been discontinued. I confirmed the one I did use was a suitable repalcement via email.
