Paging in 877a
MessUpMymind
hi there,
i am currently trying to use lookup table to simplify my program ,
below is the coding:-
pcl 	equ 03h
movlw 0x00        ;get high 8 bits of Table address
movwf PCLATH            ;save to PCLATH (may not be correct, yet)
movlw 0x80		         ;get Table low address
addwf offset,W          ;add value of offset, keep result in W
                        ;if page is crossed, carry will be set
btfsc STATUS,C          ;check page crossed? Skip next if NO
incf PCLATH             ;yes, increment PCLATH
call Table              ;call to table
org 0x50
Table:
		movwf	pcl
		retlw	0x88
		retlw	0x70
		retlw	0x38
		movwf	PORTD
		call	DELAY
what i wan to do is just display those value on PORTD , but it seem not working =(...can anybody help me??
You are using 0x80 as the table address instead of 0x50. Also the code will return after the call to table so you need something after the call.
BTW, you can use movlw low(table) to load W with the low byte. Likewise, you can use movlw high(table) for the high byte.
Hi mike,
thanks for your quick reply, i have tried as what u said
        pcl equ 02h
	movlw 0x50		        ;get Table low address
        addwf offset,w                ;if page is crossed, carry will be set
	btfsc STATUS,C
	incf PCLATH
	call Table
	movwf PORTD
	call	DELAY
org 0x50
Table:	movwf	pcl
		retlw	0x88
		retlw	0x70
		retlw	0x38
		retlw	0xff
		retlw	0xff
but seem like it doesn't light on those led , and another issue should i increase the PCL after i complete the retlw ?? or it actually will flow by it own??
your help is much appreciated!!
If you post snippets of code then it is very difficult to help. If you post an example that can be assembled then it is easy to see what is wrong. In your code above I have no idea what is in location "offset" or if you have set the port to output etc.
hi mike ,
sorry for bringing you trouble here's the complete code ,
#include "P16f877a.inc"
__CONFIG 0x399A
cblock 0x20
offset
endc
COUNT1	EQU	2DH
COUNT2	EQU	2EH
pcl 	equ 02h
org 0x00
		BSF	STATUS,5   ; set bit 5 of STATUS to change to bank 1
		BANKSEL TRISB
		clrf	TRISB
		BCF	STATUS,5
		BANKSEL	PORTB
		clrf	PORTB
	movlw 0x00        		;get high 8 bits of Table address (Page 0)
	movwf PCLATH            ;store into PCLATH
	movlw	0x50
	addwf        offset,w
	btfsc STATUS,C
	incf PCLATH
	call Table
	movwf	PORTD
	call	DELAY
org 0x50
Table:	movwf pcl
		retlw	0x88
		retlw	0x70
		retlw	0x38
		retlw	0xff
		retlw	0xff
DELAY					; common delay for all condition
		MOVLW	d'200'
		MOVWF	COUNT1
DELAY1
		DECFSZ	COUNT2,1
		GOTO	DELAY1
		DECFSZ	COUNT1,1
		GOTO	DELAY1
		RETURN
END
there's nothing on the output ..
You haven't put a valid value in offset. You are also setting PortB to output and then writing to PortD.
This should get you started,
		__config 0x399A
		cblock	0x20
offset
		endc
COUNT1		equ	2DH
COUNT2		equ	2EH
pcl		equ	02h
		org	0x00
		bsf	STATUS,5	; set bit 5 of STATUS to change to bank 1
		banksel	TRISB
		clrf	TRISB
		clrf	TRISD		;set port D to output
		bcf	STATUS,5
		banksel	PORTB
		clrf	PORTB
again		movlw	1		;start at entry 1
		movwf	offset
Loop
		movlw	0x50
		addwf	offset,w
		btfsc	STATUS,C
		incf	PCLATH
		call	Table
		movwf	PORTD
		call	DELAY
		incf	offset,f	;move to next entry
		movlw	6		;length of table
		xorwf	offset,W
		btfss	STATUS,Z	;reached the end?
		goto	Loop		;no so keep going
		goto	again		;yes so reset offset
		org	0x50
Table:		movwf	pcl
		retlw	0x88
		retlw	0x70
		retlw	0x38
		retlw	0xff
		retlw	0xff
		movlw	d'200'
		movwf	COUNT1
DELAY1
		decfsz	COUNT2,1
		goto	DELAY1
		decfsz	COUNT1,1
		goto	DELAY1
		return
		end
Mike, are you sure MOVWF PCL is not a mistake, I would think it to be ADDWF PCL?
From what I understand the way the table works is by adding to the program counter latch "PCL" you advance the program, if you add 3 it skips 3 instructions and goes to the 3rd item on the table. Do I misunderstand?
The way the code above is written it calculates the address in the table and so movwf is correct. You can use addwf but then the table cannot cross a page boundary. Try running the above code in the simulator to see the difference.
hi mike,
thanks a lot...you are always so kind helping me...it's working , if i didnt set offset it will be 255 inside right?? and that cause an error??
regards tk
If you don't write a value it will just be a random number and jump to a random point in your code. This was why it was crashing.
