Opamp transfer
dark
Hello Forum,
I have a voltage changing slowly against response to a sensor from
10V----->5V . I have 5V single supply OPamp , now how to scale it down to 0V----->5V .
Hello Forum,
Whats the type of OPA you have.??
do you know anything about the sensor? if it has a low output impedance and can source some current without distorting the signal, you may be able to scale down the sensor output prior to the op amp.
you could use a voltage divider but that would produce 2.5-5 volts output. if you want to transfer 5-10 volts into a 0-5 volts then you want to subtract not divide. I think you need a differential amplifier arrangement with a gain of 1 on both inputs
Hi ,
The Opamp I have is OPA2335 , powered with 0V and 5V . The signal I get is reverse 10V------>5V (it can be 5V---->2.5V with a divider) .But even if I subtract that I get a -Ve sign? which cannot be handeled .
Hi ,
Say you used the INV of the OPA, with a 2:1 divider so thats +5V to 0V
and if you made the OPA *1.
Input +2.5V into the NI of the OPA.
So for 0V inp you would get +5V out
and for +5Vinp you would get 0V.
Is this what you want.?:)
I am afraid I dont follow you . Do you say to use the difference amplifiers NON-INV input to be heald at 2.5V ,and the INV should be fed the input signal? . If thats the case after divider I get 5V----->2.5V , and when subtraction on the higher side is done I get 2.5-5=-2.5V ? .
The INV gain is -1 , the NI gain is 2
Dont forget the 10V signal is via a resistive divider 2:1 so it +5V to 0V
Hello Forum,
Here you go.
Hi ,
Thanks , you are right I slipped the '-1' . I think it will require a gain of 2 (or please correct me ) . holding NON-INV end at 5V . now I get 5-5*-2=0V ,5-2.5*-2=5V .
-Adi
The common mode range of the OPA2335 is -0.1V to +3.5V.
The transfer function is
Vout=10-Vin.
This must be accomplished within the common mode range.
See below.
It could be accomplished with one op amp, but the resistor values get pretty funky.
Vout=10-Vin.
See below.
hi Ron,
As you advise a dual OPA configuration would be better, the Rin/Rf are 'funky'.
Have to be careful how I type in 'funky'....:rolleyes:
Vout=10-Vin.
See below.
Hello,
Also, if a small error is acceptable and the loading wont bother the sensor,
then making R3=2k and R4=1k and eliminating U1 also works ok. That gets us
back down to one single op amp.
Hello,
Mike posted an elegant solution.
Thanks everybody for your valuable inputs .
Regards
