Short answer is yes you could probably get rid of buffer.
It all depends on accuracy specs of the circuit goals.
The buffer probably could get dropped as its load, 10K + 31.25K, would
have negligible impact on the 100 ohm, in fact its affect ~ .25% error in
the 100 ohm, the non inverting path G, assuming all R's perfect values.
The transfer f() of the converter is basically a straight line, y = mX + b,
and m is the slope/scale factor, b is the 1.2V offset controlled by pot.
One could even look into replacing the 10K, 31.25K, and buffer with just
the computed scale factor formed by the 31.25K and 10K, eg. the value
of the I to V conversion R, the 100 ohm. Assuming one uses a low Ibias
OpAmp for the diff amp portion, so that offset due to bias current of
OpAmp does not contribute significant error.
Using worst case analysis, and desired accuracy, one could eliminate the
pot if the +15V was a precision Vref. Typically its a 5% type supply, so
worst case analysis again would determine if it can be eliminated, and also
determines precision of R's needed. Alternatively use a precision 1.2V Vref
part,
PMIC - Voltage Reference are in stock at DigiKey. Order Now! Integrated Circuits (ICs) ship same day
www.digikey.com
Also OpAmp bias, Voffset, PSRR, all contribute to error, so again worst case
analysis to see if circuit meets target accuracy/precision specs is prudent.
Note the 100 ohm AND the ratio of the 31.25K/10K, and the 1.2V Vref are
the circuits most important considerations in determining G (slope) and
V offset in y = mX + b.
There are many more considerations in 4 20 ma current loops -
IntroductionWhen designing channel-to-channel isolated analog output modules for process control applications, such as programmable logic controller (PLC) or distributed control system (DCS) modules, the main trade-off is usually between power dissipation and channel density. As module sizes...
www.analog.com
Regards, Dana.
