Op Amp question
alphacat
Is there any configuration of an Op Amp (with feedback), that would give a gain equal to the ratio of two resistors - say R1/R2? (polarity doesnt matter).
Thank you.
yes.
finite impedance amplifier.
you must have read about voltage controlled voltage source.,in that if you ground v1. you will get it!
hi there
its easy i think. just need to use the op amp as an inverting amp ,ie input to the negetive terminal
the gain will be -R1/R2
