op amp question
ahivarn
calculate full power bandwidth for amplifier using ic741 OP AMP if Voutput is 5 volts peak to peak.
plz help
audioguru
Most Helpful Member
Look at the datasheet for Texas Instruments uA741. Its Slew Rate is spec'd at typically 5V/us. Then calculate its bandwidth at 5V p-p.
The datasheet has a graph for its Maximum Peak Output Voltage vs frequency that shows its full power bandwidth at various peak voltages.
